3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Matt's Original Inverted Planter a.k.a IPlanter.
Matt\
Step 1Why.
Why.
The logical choice for my indoor gardening is 1: container and 2: hanging. So after doing a few searches on the net I had come across a few options. There were of course the usual hanging planters that are really nothing more than a regular pot with strings tied to a ceiling hook. These really didn't appeal to me due to previous experiences where the water flowed down through the soil and filled the overflow basin at the bottom. Another option is hanging inverted planters which have been around for a very long time. Some in a much older design made from terra cotta in a traditional Mexican style and a newer one made of plastic that had internal foam spacers for dirt/water containment.
This naturally put my mind into make it myself mode. Whenever I get one of my project ideas. I start drawing different options in paint. I wanted it to be a conical-type container for water retention purposes. After drawing a few designs the one I decide on was to use a inverted 2 liter soda bottle with a few modifications to make it better suited for planter use.
87 comments
1-40 of 87next »
Mar 30, 2012. 7:11 AMondoratmo says:
thanks for inspiring me, this is one of answer of urban agriculture technique.
I'll try to develop it.
Nov 21, 2011. 7:46 AMgeckomage says:
hey, does this method work with all plants or just some? because i know many different plants have their roots which grow towards gravity, and the plant which defies gravity. does the inverted thing trick it? >:3 im decent with plants. but my specialty is electronics and being a redneck(what would the world be like without em). so please excuse the sillyness of my question :P
Sep 9, 2009. 3:20 AMAstralQueen says:
I use this kind of planter to plant my cat's cat nip. This way, he can't knock the pots over and roll around in the crushed leaves and dirt and then later on sleep on my bed with clean sheets leaving dirt marks and soil all over the place. :D
Jul 17, 2011. 11:21 AMSilver Diva says:
Sounds like some parties I attended in the 70's!
May 31, 2011. 4:50 PMcaptain Jack says:
you just HAVE to mess with the order of things, don't you....
Mar 16, 2011. 5:33 AMtinic says:
Thanks for the tutorial but I'm wondering why people use this technique: because of lack of space?
thanks
Mar 11, 2011. 11:24 AMjanetsellers08 says:
Great job in the instructions, and inspiring, too. thanks.
Nov 25, 2010. 8:05 PMdesya says:
I knit with plarn (plastic bag yarn) could be used to build a harness if you are worried about the support holes...2 for 1 recycling.......
Nov 24, 2010. 6:06 PMdesya says:
ok this is really smart always was annoyed at the amount of water lose to what I had just watered
Jun 1, 2010. 12:14 PMrpm1960 says:
yes, I was concerned about string strength as well, especially since the soil will get really heavy once it soaks up water.  I'm putting one together (cilantro seeds in the top) but will suspend it in the red mesh bag my store bought onions came in.  It won't look as dainty as these, though~
Apr 29, 2010. 5:48 PMredorchestra says:
For the people worried about the rope splitting the bottle you might find some small grommits that would ease the strain, or thicker string like shoe laces would spread the weight more.
I am going to make a few of these but I am going to poke small holes in the bottom of the bottle, ( the one that is cut off and discarded) invert it and re-insert it. It will be a sprinkler for the soil, so it doesn't just run down the side. and it will retain some moisture, so the soild doesn't dry out too easily.
Apr 20, 2010. 2:30 PMdarrylm says:
This is so awesome. I plan to plant 5 this year alone. Hoping my tomato seeds do better as I only have 2 thriving seedlings and its been 4 weeks! My idea for this will be to try the boiling water method as I do not have a heat gun. I think I will try running string down through the hole and attaching it to the threaded part of the bottle. Then as it is heating up, i can pull upwards and hopefully it will invert. I will let you know. THANKS AGAIN!
Apr 20, 2010. 2:32 PMdarrylm says:
OH YEAH! For those frugal gardeners like myself. Plant some herbs on the top. I was told this is a great method for doubling your planter space. Seems to be quite popular.
Mar 22, 2010. 1:36 PMJonesy Boogieman says:
This was an excellent instructable! Thank you!  I'll be doing this as soon as my tomato and cucumber seedlings are big enough!
Can you post a picture of these planters with full grown plants please?  Thanks!
May 17, 2009. 11:54 PMdemee62 says:
Great idea!! I know that I can master this one. I can have me a garden this year that the dog can't destroy.
Mar 22, 2010. 1:34 PMJonesy Boogieman says:
This made me laugh! I can just picture a dog standing below, looking up at it, tail wagging slowly, like Jaws, but unable to reach. Thanks for the laugh!
Feb 26, 2010. 7:17 PMjoeymmeezz says:
 im new at this but don't yon need something to support the plant
(if it was a tomatoe plant)
Feb 27, 2010. 8:22 AMjoeymmeezz says:
 ok thank you
Feb 26, 2010. 7:14 PMjoeymmeezz says:
 kool
Jan 18, 2009. 1:29 PMlaresekae says:
if you don't have a heat gun, you could probably dip the top of the bottle in a pot of hot water to soften it enough to do the job...
Feb 10, 2010. 10:27 AMriteandritual says:
 Just under boiling is usually fine. I tried to 'sanitize' a soda bottle once using boiling water (this was before I heard of chemical horrors that seep out of them at high temps) and ended up with a wrinkled, deformed lump of a bottle.
I guess the most tricky thing would be to localize the heat, and get the temp right, not too hot...
Dec 25, 2009. 8:26 PMKaber says:
is the string in the holes of the bottle sturdy enough to hold a plant once it is full of tomatoes? I would think it'd be heavy and the holes in the thin plastic bottle would rip. How well does it do with weight?
Dec 25, 2009. 10:14 PMHolyTracker says:
Love it! 3 done and more in the way! Thanks for sharing the idea
May 17, 2009. 12:36 AMTheJman says:
Cool planter but I just have a question or two..How well will the plastic bottle hold up when there is a full load of tomatoes on the plant? Will the 3 holes hold without splitting and letting the whole works fall?
Aug 12, 2009. 12:16 PMsgsidekick says:
If you're worried about the weight of the fruit, I'd just run a piece of duct tape around the top, folding half of it inside as well, then punch a few more holes...maybe 6 in total, to run the string hangers through. And I'd use garden twine, not just any ole string, as the hanger. Just my 2 cents...
Dec 25, 2009. 8:29 PMKaber says:
oops. I should have waited till this page to ask the same question. I was thinking of running the string/twine under the bottom (or inverted top) as well.
thanks for the further ideas.
Oct 29, 2009. 1:16 PMrdemunck says:
Wow!  This is great.  What a fascinating idea.  Thanks!
Aug 10, 2009. 10:50 AMmark429 says:
Very Nice Instructable! I am going to be converting some 3 liter bottles this afternoon!!! (maybe some 1 & 2 liter bottles as well) I can't believe my mom paid $15 for a Topsy Turvy when we could've made one of these for free (practically) Thanks Again. Good Job!
Jul 23, 2009. 1:55 PMcoyotehope says:
Thank you this one is not to much work and a Very excellent starting point for me. Thank you so much for sharing!
Jul 14, 2009. 6:21 PMNinzerbean says:
This is great because my cat won't be able to dig in the dirt - I haven't had a house plant in 3 years because of him.
Jun 29, 2009. 8:43 AMzuppod3 says:
EXCELLANT ! Well written and researched. You must be an engineer or tech.
Jun 25, 2009. 8:18 PMplum0214 says:
I can't belive I bought one from the store before I saw your's. Your's does the same thing and is alot cheaper. Great job..
Jun 21, 2009. 7:35 PMgreybunny says:
I like the idea but yours is the only one I've seen that looks nice and feasible. I think I'll make one when I get home with a flowering vine.
May 9, 2009. 8:21 PMarirang777 says:
This detail alone is the responsible for pushing me out of the sofa and moved me into making my own, inverted conical hanger, or as you titled it: iPlanter. Thanks Mattl. Fave'd it already
May 3, 2009. 4:10 PMbizgold2000 says:
If your looking for a larger container, We have found heavy thickness One Gallon containers from Apple Juice do the same trick as 2 liter bottles and once again , they are thicker and still work with the heat gun method. Steve Smith
May 6, 2009. 11:47 AMtatihana00 says:
thanks. i was thinking what i should do with my apple juice containers. how did yours come out?
1-40 of 87next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:mattl(OhCripes.com)
