loading
Step 9: Make sure that only the plant gets water, not your floor!
I took this picture to demonstrate how the water can sit in the bottom of the planter for the roots to soak up. With this method, the chance of leaks are virtually non-existent providing you don't get crazy with the watering.
IF YOU CAN FIND ARROWHEAD WATER THEY HAVE A 3 LITER WATER JUG THAT SAVES THE STEPS OF MELTING WITH MINIMAL EFFORT :)
A larger bottle will certainly produce larger happier plants. There are also a few generic brand 3 liter soda bottles out there.
<p>I've been reading on and on about hanging tomatoes &amp; other various garden ideas, trying to find the best option for my situation. I have to say that your Instructable was the best yet. Not only is it a great idea, but it was an entertaining read as well, complete with easy-to-follow instructions and random humor! I <strong><em>loved it</em></strong>; thanks so much for sharing!</p>
Thanks for the kind comments, happy planting!
<p>Cool concept. I've been using soda bottles as planters for a while myself. One thing I've learned is if you use the green plastic, you don't have to worry about algae or root burn inside the bottle. I also use an old soldering iron to cut the plastic. Make sure you do it outside in a well ventilated area, fumes are toxic..</p><p>Also if you cut a smaller hole in the bottom of the bottle (now the top) you keep the ribs which would give you more structural stability and you can put the rope at the ends of the ribs in the plastic.</p>
Green bottles work great. Of course you can paint as well. Your suggestion of cutting a smaller section off is a good one.
<p>that very smart</p>
Seriously cool!<br>Bought a topsy-turvy planter, only lasted one season! Too much to try again!<br>Can use a hairdryer, as I use for embossing and it works!<br>Will send pics if plants survive!
<p>Very nice project, I will make one with my kids to plant tomatos. Thanks for sharing it.</p>
<p>This is a great and unique idea</p>
<p>I loved!!... </p>
Great job. I was just shopping today for a decent hanging planter that doesn't leak on the floor.
Finally! A way to have houseplants my cat can't tear out! Thank you! :)
thanks for inspiring me, this is one of answer of urban agriculture technique.<br>I'll try to develop it.
hey, does this method work with all plants or just some? because i know many different plants have their roots which grow towards gravity, and the plant which defies gravity. does the inverted thing trick it? &gt;:3 im decent with plants. but my specialty is electronics and being a redneck(what would the world be like without em). so please excuse the sillyness of my question :P
I use this kind of planter to plant my cat's cat nip. This way, he can't knock the pots over and roll around in the crushed leaves and dirt and then later on sleep on my bed with clean sheets leaving dirt marks and soil all over the place. :D
Sounds like some parties I attended in the 70's!
you just HAVE to mess with the order of things, don't you....
Yes. I have two tomatoes hanging off each end of my clothes line poles right now as a matter of fact.
Thanks for the tutorial but I'm wondering why people use this technique: because of lack of space? <br>thanks
Great job in the instructions, and inspiring, too. thanks.
I knit with plarn (plastic bag yarn) could be used to build a harness if you are worried about the support holes...2 for 1 recycling.......
ok this is really smart always was annoyed at the amount of water lose to what I had just watered
yes, I was concerned about string strength as well, especially since the soil will get really heavy once it soaks up water.&nbsp; I'm putting one together (cilantro seeds in the top) but will suspend it in the red mesh bag my store bought onions came in.&nbsp; It won't look as dainty as these, though~<br />
For the people worried about the rope splitting the bottle you might find some small grommits that would ease the strain, or thicker string like shoe laces would spread the weight more. <br /> I am going to make a few of these but I am going to poke small holes in the bottom of the bottle, ( the one that is cut off and discarded) invert it and re-insert it. It will be a sprinkler for the soil, so it doesn't just run down the side. and it will retain some moisture, so the soild doesn't dry out too easily.
This is so awesome. I&nbsp;plan to plant 5 this year alone. Hoping my tomato seeds do better as I only have 2 thriving seedlings and its been 4 weeks! My idea for this will be to try the boiling water method as I do not have a heat gun. I think I&nbsp;will try running string down through the hole and attaching it to the threaded part of the bottle. Then as it is heating up, i can pull upwards and hopefully it will invert. I will let you know. THANKS&nbsp;AGAIN!<br /> <br />
OH&nbsp;YEAH! For those frugal gardeners like myself. Plant some herbs on the top.&nbsp;I&nbsp;was told this is a great method for doubling your planter space. Seems to be quite popular.<br />
&nbsp;im new at this but don't yon need something to support the plant<br /> (if it was a tomatoe plant)
No, anything you can grow in the container that size should support itself.&nbsp; You'll notice in a few comments below about how this really isn't a suitable growing method for anything larger than cherry or plum tomatoes and at largest Roma. However they require more growing space and nutrients so a larger container should probably be used.<br />
&nbsp;ok thank you
&nbsp;kool
if you don't have a heat gun, you could probably dip the top of the bottle in a pot of hot water to soften it enough to do the job...
Yes, that should work as long as it is very hot, possibly boiling. A hair dryer may also do the trick.
&nbsp;Just under boiling is usually fine. I tried to 'sanitize' a soda bottle once using boiling water (this was before I heard of chemical horrors that seep out of them at high temps) and ended up with a wrinkled, deformed lump of a bottle.&nbsp;<br /> I guess the most tricky thing would be to localize the heat, and get the temp right, not too hot...
is the string in the holes of the bottle sturdy enough to hold a plant once it is full of tomatoes? I would think it'd be heavy and the holes in the thin plastic bottle would rip. How well does it do with weight?
That really depends on the type of string you use and thickness.&nbsp; The stuff I used had a weight rating of 40lbs.&nbsp; It never tore through the plastic bottle either.&nbsp; If you are concerned about that happening I&nbsp;would just reinforce the holes with a little hot glue.&nbsp; If you use a paper punch to make the holes you will get nice clean cuts.&nbsp; Circles are Very strong and can support a lot of weight.<br />
Love it! 3 done and more in the way! Thanks for sharing the idea<br />
Cool planter but I just have a question or two..How well will the plastic bottle hold up when there is a full load of tomatoes on the plant? Will the 3 holes hold without splitting and letting the whole works fall?
If you're worried about the weight of the fruit, I'd just run a piece of duct tape around the top, folding half of it inside as well, then punch a few more holes...maybe 6 in total, to run the string hangers through. And I'd use garden twine, not just any ole string, as the hanger. Just my 2 cents...
oops. I should have waited till this page to ask the same question. I was thinking of running the string/twine under the bottom (or inverted top) as well.<br /> thanks for the further ideas.
Wow!&nbsp; This is great.&nbsp; What a fascinating idea. &nbsp;Thanks!
Very Nice Instructable! I am going to be converting some 3 liter bottles this afternoon!!! (maybe some 1 & 2 liter bottles as well) I can't believe my mom paid $15 for a Topsy Turvy when we could've made one of these for free (practically) Thanks Again. Good Job!
Thank you this one is not to much work and a Very excellent starting point for me. Thank you so much for sharing!
This is great because my cat won't be able to dig in the dirt - I haven't had a house plant in 3 years because of him.
EXCELLANT ! Well written and researched. You must be an engineer or tech.
I can't belive I bought one from the store before I saw your's. Your's does the same thing and is alot cheaper. Great job..
I like the idea but yours is the only one I've seen that looks nice and feasible. I think I'll make one when I get home with a flowering vine.
Great idea!! I know that I can master this one. I can have me a garden this year that the dog can't destroy.
This detail alone is the responsible for pushing me out of the sofa and moved me into making my own, inverted conical hanger, or as you titled it: iPlanter. Thanks Mattl. Fave'd it already
If your looking for a larger container, We have found heavy thickness One Gallon containers from Apple Juice do the same trick as 2 liter bottles and once again , they are thicker and still work with the heat gun method. Steve Smith
About This Instructable
88,764views
407favorites
License:
More by mattl:Make a super cheap, easy and comfortable to use sanding block. How to make a towel or coat rack. How to make a glass box of emotion.
Add instructable to:
