All About Max Sonar EZ0 and Arduino
Published
Introduction: All About Max Sonar EZ0 and Arduino
About: Maker, PCB designer , electronics instructor from Jordan just one word ! I Adore electronics follow me on FB https://www.facebook.com/Mohannad-Rawashdeh-Raw-774983565988641/
I Searched In the Internet about EZ0 Ultrasonic And I found Many information in the datasheet for this sensor , I will show you how we can program this sensor in Arduino IDE .
At first , the Datasheet " You can see it Here " Have all Specification and Features For this sensor .
The EZ0 Sonar detects objects from 0-inches to 254-inches (6.45-meters) and provides sonar range information from 6-inches out to 254-inches with 1-inch resolution. Objects from 0-inches to 6-inches typically range as 6- inches
This sensor Has 3 Output formats To interface with :
1 ) Analog interface .
2) Pulse width Modulation "PW".
3) Serial Interface .
Material :
1) Arduino Board " I used Arduino Nano".
2) Ultrasonic Max Sonar EZ0 .
3)Wires and BreadBoard .
Download the library for this sensor from HERE
Step 1: Analog Interface
The Analog Interface is the easiest way to communicate with this sensor , there is a directly proportional between Distance and Output voltage .
Outputs analog voltage with a scaling factor of (Vcc/512) per inch .
For example , a voltage supply of 5V yields ~9.8mV/inch , a voltage supply of 3.3 V yields ~6.4mV/inch.
The analog Output voltage not accurate rather than PW And serial . so I prefer to use PW or serial .
this is a simple code :
// Written by : Mohannad Rawashdeh
// this code foe EZ0 Max sonar , analog interface
// https://www.instructables.com/member/Mohannad+Rawashdeh/
float Inch=0.00;
float cm=0.00;
int SonarPin=A0;
int sensorValue;
void setup(){
pinMode(SonarPin,INPUT);
Serial.begin(9600);
void loop(){
sensorValue=analogRead(SonarPin);
delay(50);
Inch= (sensorValue*0.497);
cm=Inch*2.54;
Serial.println(sensorValue);
Serial.print(Inch);
Serial.println("inch");
Serial.print(cm);
Serial.println("cm");
delay(100);
Step 2: Pulse Width "PW" Interface
Pulse width "PW" Is another way to communicate with this sensor .
This pin outputs a pulse width representation of range. The distance can be calculated using the scale factor of 147uS per inch.
So using Pulse in to calculate the distance .
I prepared This Library for this method , You can Download from attachment .
This code without Library and with Median/Mode filter :
// this code Based on : http://playground.arduino.cc/Main/MaxSonar
int pw_pin=7;
int arraysize = 9;
int array[] = { 0, 0, 0, 0, 0, 0, 0, 0, 0};
long inch;
int exact_cm_value;
void setup() {
// put your setup code here, to run once:
pinMode(pw_pin, INPUT);
Serial.begin(9600);
void sensorRead(){
for(int i = 0; i < arraysize; i++)
inch = pulseIn(pw_pin, HIGH);
array[i] = inch/58;
delay(10);
void array_arrangment(int *a,int n){
// Author: Bill Gentles, Nov. 12, 2010)
for (int i = 1; i < n; ++i)
int j = a[i];
int k;
for (k = i - 1; (k >= 0) && (j < a[k]); k--)
a[k + 1] = a[k];
a[k + 1] = j;
int filter(int *a,int n){
int i = 0;
int count = 0;
int maxCount = 0;
int filter = 0;
int median;
int prevCount = 0;
while(i<(n-1)){
prevCount=count;
count=0;
while(a[i]==a[i+1]){
count++;
i++;
if(count>prevCount && count>maxCount){
filter=a[i];
maxCount=count;
median=0;
if(count==0){
i++;
if(count==maxCount){//If the dataset has 2 or more modes.
median=1;
if(filter==0||median==1){//Return the median if there is no mode.
filter=a[(n/2)];
return filter;
void loop() {
// put your main code here, to run repeatedly:
sensorRead();
array_arrangment(array,arraysize);
exact_cm_value= filter(array,arraysize);
Serial.print("The distance = ");
Serial.print(exact_cm_value);
Serial.println(" cm ");
delay(100);
Library code :
#include "SonarEZ0pw.h"
SonarEZ0pw Sonar(7); // pin D7
float cm_dis=0.00;
float Inch_dis=0.00;
void setup() {
Serial.begin(9600);
void loop() {
cm_dis= Sonar.Distance(cm); // To calculate the distance in cm
Inch_dis=Sonar.Distance(inch);// To calculate the distance in Inch
Serial.println("Distance " );
Serial.print(Inch_dis);
Serial.println(" inch ");
Serial.print(cm_dis);
delay(250);
Step 3: Serial Interface
In this method i will use SoftwareSerial library to write the code for this sensor ,
And we will Connect D4 With BW , Leave it  open or hold low for serial output on the TX output .
The output is an ASCII capital “R” which equal 0x52 , followed by three ASCII character digits representing the range in inches up to a maximum of  255, followed by a carriage return (ASCII 13 or 0x0D)
the image show Logic  Analyzer and the Output on it
code :
// written By : Mohannad Rawashdeh
// http://WWW.Genotronex.com
// genotronex@gmail.com
// this code to test EZ0 Sonar sensor using Serial method .
// Connect Tx....D8
// Connect Rx ....D9
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8, 9,true); // RX, TX
int BW=4;
char *buffer;
byte x;
char array[3];
int counter=0;
void setup() {
  // set the data rate for the SoftwareSerial port
  Serial.begin(9600);
  mySerial.begin(9600);
  pinMode(BW,OUTPUT);
  digitalWrite(BW,LOW);
  delay(250);
  Serial.println("Calibrartion Cycle ");
  delay(150);
void reading(){
  mySerial.println(1);
while (mySerial.available())
   x= mySerial.readBytes(buffer,1);
   if(*buffer==0x52){
   array[0]=*buffer;
   array[1]=*buffer;
   array[2]=*buffer;
delayMicroseconds(220);
void loop() {
  reading();
  int Final_inch=(array[0]-48)*100 + (array[1]-48)*10 +(array[2]-48) ;
  float Final_cm=Final_inch*2.54;
  Serial.print(Final_inch);
  Serial.println(" Inch ");
  Serial.print(Final_cm);
  delay(200);
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    1 Questions
    hallo, i want to ask about this sensor. i want to find range under water. can i use this sensor to find the range in water field?
    this sensor will not work under water , this is not waterproof sensor
    11 Comments
    can i use to for motion detection please? to count people passing through the door?
    Hi, i am using the analog way to calculate the distance, however i would like to know why did u multiply the sensorvalue by 0.497 to get inches, cause i read that 5/512 is used as a scaling factor to calculate in inches?
    I tried this sensor. it works fine , but i tried fixing it into 4" dia pvc pipe it doesn't work as it has to.. how to fix this sensor inside the pipe? help me out...
    email me at : look4ursoul@live.com
    will be very grateful.
    What is the beamwidth of this sensor?
    can i send the output data through a bluetooth shield?
    Hi. I have tried these coding in my project to test the sensors. and it works! thanks. However, I am using 7 LV Maxsonar Ultrasonic Sensors for my blind detection system to detect obstacles. Somehow there is errors in my coding. Would you help me?
    Can you use this to alarm when something is moving toward you very quickly? IE to mount on the front of a vehicle to help keep you from running into someone that is stopped. Maybe later to activate a break.
    please explain more .
    Reading a sensor value , store it in a variable and the convert it to string and send it .
    how can i use it with xbee?
