3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mayan Chocolate Drink
Chocolate was first cultivated by the Ancient Mayans, however the way they consumed it was not much like the sweet treats we know today. Their preferred method of consumption was a thick, bitter, frothy drink served cold. This instructable chronicles my attempt to make such a beverage.
I feel the need to point out that this is more of a historical experiment than a recipe. The results will most likely not be to the taste of modern people. However, if you're interested in experiencing the past through your taste buds (however painful the process ~.^) read on!
Step 1Ingredients
Ingredients
First of all, we need to gather our ingredients. We need:
- 1/2 cup raw cocoa beans
- 2 medium sized dried chilis
- 1/2 tsp cinnamon
- 1/4 cup cornmeal
- ~6-8 cups water
- honey to taste (optional, and not entirely accurate)
This will make about 4 mugs worth of the concoction. I made it a mug at a time trying to refine the recipe. More on that later.
Yes, the picture shows cinnamon sticks, and my original attempt involved grinding the sticks in my mortar & pestle with everything else, however, unless you are an authenticity masochist (which I occasionally am) I recommend using ground cinnamon. Grinding sticks in a mortar and pestle is hard as heck, and trust me, you'll be doing enough grinding. (Also, I'm not sure cinnamon is entirely accurate, but I'm not going to sweat that now)
The only ingredient that I anticipated having trouble finding was the raw cocoa beans, however I found them quite easily at my local health food store. The package billed them as a "raw superfood" so I tried one raw. I don't recommend it... Moving on...
58 comments
1-40 of 58next »
Mar 29, 2012. 5:15 PMBrenBren says:
Masa is different from cornmeal in a couple ways, obviously it's much finer, but it's also made from Hominy (nixtamalized corn) which has quite a different flavour (ie the flavour of tamales or corn tortillas). Not sure what is more historically accurate, but Mexican Atole uses masa.
Grinding the beans: I know an old Samoan lady who makes a drink called Koko Samoa, which is pan roasted cocoa beans that are ground, re-formed, and dried, then later grated into boiling water with sugar; it is delicious! But my point is that to grind the beans, she uses a glass bottle full of water and a tupperware container - says it works way better than a mortar and pestle. Maybe it's worth a try?
Jul 7, 2011. 5:13 PMlvilla7 says:
A+ for the effort and willingness to go through the whole experiment.
Some ideas:
1.- Roast cocoa beans at a lower temperature for a longer time. Burnt beans will taste bad. that alone could ruin the whole thing.
2.- Use just a little chile, and bea in mind that there are many different types of chiles. Some are smoky, some add color, some are very hot.
3.- Use just a little corn flour or masa so it won't thicken too much
4.- to make it froth in Mexico we use a molinillo or Mexican Whisk (see pic). It is moved between the palms of your hands and will surely make it froth. A modern approach woudl be to use a Moulinex type submersible blender.
While most historians say that chocolate was consumed in a wasy similar to what you made, others say that honey or agave nectar was used to sweeten it.
Good Luck!
Jun 19, 2011. 10:01 PMacoleman3 says:
very interesting. i may like it actually cus i like flavors such as this. i remember back in job corps, they had packets of hot chocolate and id put a couple dashes of tobasco in it to give it some "kick". i loved the humor you put in this and good show on your procedures.
May 31, 2011. 1:44 PMgodbacon says:
I love it!
I think your meant to let it stand for a day.. (ferment) add a pinch of yeast or leave it on the porch in the wind.
oh and cooking over an open fire would add a bit of smoke and wood ash (alkaline) to mellow out the acids and help convert the corn.
things cooked out doors taste different...
love it!
May 31, 2011. 10:22 PMdeyb1 says:
godbacon is right about there being fermentation in there. I'm pretty sure the beans, themselves, were fermented before grinding, probably after toasting. And the vanilla would have been fermented as well. If you don't like the idea of using wood ash with the corn, you could try pickling lime water. Pickling lime like you would use to make pickles. I don't know a lot about this recipe, but I've been researching fermenting for quite a while and have run across mentions of this drink several times. Good on ya for posting!
May 29, 2011. 8:18 PMsendai says:
Just a quick note the people, culture, food, etc., are Maya, while the language is Mayan. It's an interesting somewhat obscure linguistic quirk. :)
May 28, 2011. 3:42 PMdrabinowitz says:
Are you sure that the corn meal is really necessary?
May 27, 2011. 8:02 AMGebcas says:
Not really accurate men
May 27, 2011. 10:52 PMzombiefire says:
it was actualy the aztecs who made it first
May 26, 2011. 9:30 PMclara27 says:
Well, you almost got it right, except for the lack of vanilla and a few other spices.
And yes, it´s suppose to tasts bad. It wasn´t until some nuns in a convent added the cinammon and the sugar that this drink began its road to stardom.
And the frothing won´t work unless it has the most important ingredient, supplied later by the french: milk.
Today the drink does not contain chilis or cornmeal. That would be closer to champurrado--made with cornmeal, chocolate and brown sugar.
And the chili and spices mixed with chocolate and sugar make Mole, a dark sauce served over chicken and pork meat.
Nevertheless, it was a good try and an entertaining read.
May 26, 2011. 3:44 PMscintnl says:
Mayans did not have cinnamon. They did have honey from stingless bees (they bite, though). Sweetening with fruits would ferment the concoction quite rapidly in the jungle heat.
They did have vanilla and corn flour. Corn flour must have been used the same way as in atole.
Chocolatl is a Nahuatl word, not Mayan. The Mayan word was cacao.
Very interesting instructable.
May 26, 2011. 8:43 PMmatcovich says:
Thanks for the info. Love getting the history of words. :)
May 26, 2011. 7:58 PMBroom says:
Kudos for trying! I've always wanted to. Obviously, they didn't drink a wretchedly bad brown goo, so there's got to be a trick to the proportions, prep... or maybe the Spaniards just got it wrong somehow (forgetting to mention the ton of cream and honey would do it!).
May 26, 2011. 11:19 AMyoav115 says:
About the Chillies..
there is a Chilli called Mulato pepper, and it is not very hot, You can get it between mild and medium.
and about The corn meal, They had many types of corn, and one was right for this..
I love the attempt !
For what do we live otherwise ??
May 26, 2011. 1:09 PMbowmaster says:
It may not taste good, but these would be an antioxidant bomb. If you drank a cup of these a day you'd live forever.
May 26, 2011. 2:19 PMClutzie says:
This has been a most entertaining read. I was wondering however, if a coffee grinder wouldn't have been a better fit than the mortar and pestle gimmick. (I, for one, am not so masochist – and I'm pretty sure the Mayan would have done likewise… had they had a socket to plug their mill into).
Another thing: did you strain this concoction? This will certainly make it less harsh.
Anyway, glad to see you did not go blind or anything ;-) Nice job!
May 26, 2011. 2:00 PMcbrannan says:
good trial run! You might be after Champurrado - which is much tastier, and is the modern version of the ancient oirginal you attempted. Please note that using Masa(or Masa Harina) is THE corn based flour you would need to use, not yellow cornmeal/flour we in the states are used to seeing. And for those who wanna give this ancient drink a shot as our friend did, try grinding your beans and chiles in a coffee bean grinder. I keep one for my beans, and one as a whole spice grinder. (just make sure its a decent brand and not a cheap one, its does make a difference in the power). I'm a Chef, (I received my formal education at Le Cordon Bleu and was also a Head Chef of a Mexican restaurant where I made many Mole's from scratch (hence the info on the grinder trick) Good job! Great pics! Thanks!
May 26, 2011. 1:10 PMKatAndo says:
This was a hilarious and wonderful read. I like how you think :)
Thanks for putting it up, regardless of the flavor.
May 26, 2011. 9:20 AMorgotloth says:
Traditionally it is sweetened with a tropical fruit (i suggest mango)
On a further note, the name of this drink is chocolatl. It also commonly contained chicken or beef broth.
May 26, 2011. 9:47 AMlittlebadwren says:
Actually this sounds more like Atole...Chocolatl was the Aztec version, and typically would not have used any sweetening agent...at least that is my understanding.
And the only reason I know this is we are currently in a home-school co-op on pre-Colombian civilizations and just finished studying Mayan culture and we made this (we left out the chiles to make it more kid-friendly)...everyone loved it! We used a Mexican brown sugar as a sweetener...
May 26, 2011. 12:48 PMorgotloth says:
fair enough, he does say Mayan and not Aztec, they are rather similar though.
May 26, 2011. 9:30 AMorgotloth says:
you also need vanilla
May 26, 2011. 9:28 AMjsvans says:
everything seems to go well up to the cornmeal. I am wondering if maybe the "corn" isn't actually supposed to be meal, but corn made into some form of sugar (if not cornsyrup)
May 26, 2011. 10:23 AMemedina3 says:
Polenta is cornmeal but I don't think that's it. Perhaps more authentic is the "masa" (cornmeal) that is used for making corn tortillas or the masa that is used for making tamales. (very similar) You can find these at Mexican stores.
May 26, 2011. 9:31 AMorgotloth says:
the cornmeal acts as an emulsifier, It keeps the fresh cocoa from separating in the water.
May 26, 2011. 10:13 AMjsvans says:
cornsyrup and or cornoil would act as an emulsifier as well, along with cocoa butter, that being said.
I would think cornflour might be better than cornmeal, as it is ground much finer. I truly admire your diligence and persistence, honestly it LOOKS great in the photos. All that work deserved a vote imo.
May 26, 2011. 9:58 AMchica.emmer says:
The vanilla the Mayans were probably using (if they used it) was the vanilla pod of the vanilla orchid, which is actually native of Mexico. The one you show in the picture, is not a true vanilla bean.
May 26, 2011. 6:25 AMtonic says:
What's the historical source of the recipe?
1-40 of 58next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:AnachronistCook(Anachronist's Cookbook)
I make stuff. It's what I do. I like making things that people just don't make (or make from scratch) anymore. Why? I don't know. I guess I'm just fascinated by the origins of things.
