The original scope's construction modification is minimal and easily reversible. But most likely will void your warranty. Be especially careful while handling the mirrors during full disassembing of the OTA.
Inspect the attached Google SketchUp 1:1 model file for all of the details and measurements.
Your comments are welcome!
FocuserKnob.skp121 KB
Remove these ads by
Signing UpStep 1Major modification
The width of the groove to be milled depends on the diameter of the set screw you have. The grove is about 1.5 - 2mm deep in order to include the top narrow part of the shaft. The set screw should easily slide in the groove, but without much of freedom to prevent back lag.
Anyhow, the goal was to have some visual feedback while focusing. For example, you can check the values for the two opposite focusing positions which are definitely start getting out of focus, and then choose the average value to set (it works, I have about 8 points between these positions with the default Plossil 26mm). The average will be definitely closer to the perfect focus than any guess.
Another argument for the dial is the professional astronomers trick in the astrophotography. They make shots with all of the dial values between these no doubt out of focus positions and determining the best focus positions comparing the result images. Thus eliminating any guess work.
Also I plan to measure the perfect focus value for all of my eyepieces with the barlow and without, with 45 deg erector prism, and with the visual back adapter, e.t.c. So, I could just attach an accessory, set the dial to the specific value and use the scope.
Nope, the tip is for the flexible focuser :-) The best weight placing idea I plan to implement is here: http://www.weasner.com/etx//techtips/counterweight3.html
