3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Measure Muscle Sounds! Part 1: Electronic Board
This is a step-by-step guide on how to make your very own prototype acoustic myography sensor. That means a sensor you can use to measure muscle sounds and other physiological vibrations. What is this good for? well... it is a more affordable alternative to the electrodes used in powered prostheses (specially if you make your own). To see what else you can do with these sensors, check out these videos.
The short paper below describes briefly how this sensor works and the diagram illustrates how it is built. For more details, check my MASc thesis. There are also some videos of the sensor in that page that you can check out.
Have fun!
Step 1Bill of Materials
Bill of Materials
Here is a detailed bill of materials with suppliers and part numbers. The circuit schematics are also included at the bottom.
Part: printed circuit board (PCB)
Supplier: Any PCB manufacturer... or make your own!
Qty: 1 per sensor
Part: Knowles Acoustics BU-27135 Accelerometer
Supplier: Digi-Key BU-7135-ND ($39.85 for 1 - minimum order 500)
Qty: 1 per sensor
Part: Panasonic WM-63PRT Omnidirectional Microphone
Supplier: Digi-Key P11961-ND ($3.47 for 1)
Qty: 1 per sensor
Part: SMD Resistor 33.0k 1/10 Watt 5% 0805
Supplier: Digi-Key RR12P33.0KDCT-ND ($0.14 for 10)
Qty: 2 per sensor
Part: SMD Resistor 5.6k 1/10 Watt 5% 0805 SMD Resistor
Supplier: Digi-Key RR12P5.6KDCT-ND ($0.14 for 10)
1 per sensor
Part: SMD Resistor 2.2k 1/10 Watt 5% 0805 SMD Resistor
Supplier: Digi-Key RR12P2.2KDCT-ND ($0.14 for 10)
1 per sensor
Part: Ceramic capacitor 1uF 16 Volt 0805
Supplier: Digi-Key PCC2249CT-ND ($0.13 for 10)
2 per sensor
Part: Ribbon Cable
Supplier: Any surplus electronics store
Qty: 2.5 Feet
22 comments
Feb 5, 2010. 7:19 AMm.hussien says:
first i want to thank you as this demonstration helped me allot during my work ..but i need to know what kind of signal processing is used in order to view the signal ..or where can i get that kind of information.
Nov 16, 2009. 10:43 AMthepelton says:
What kind of sounds would you get if you ran it through an amp?  Could you make your own precussion backup to music by dancing or moving with the sensors on?
Aug 1, 2009. 3:25 PMendolith says:
Would it make sense to use a digital accelerometer and subtract the waves in software? Is the amplitude of the audio signal much smaller than the amplitude of the acceleration signal? Maybe something like the DRL+ diff amp circuit in an EEG would be useful, to cancel out the acceleration electronically even if the person is moving around a lot. Were you able to find any recordings?
Jun 22, 2007. 7:07 PMBiotele says:
maybe you can hack a Wii joystick it has a three axis acc. the heart sounds are fantastically clear! It is better than the commercial electronic stethoscopes.
Jun 13, 2007. 7:35 PMmailsummit2000 says:
nice instructions. where do you buy an Accelerometer?
Apr 2, 2007. 1:02 PMendolith says:
The accelerometer does not appear to be accessible to the kinds of hobbyists who are going to follow these directions. What properties are important for the accelerometer and microphone to have, so we can suggest substitutes? Low-frequency response seems to be the major factor. What else? Sensitivity? Noise?
Apr 6, 2007. 11:02 AMendolith says:
The ADXL32x series is cheaper ($8.60) and more obtainable (Newark and Digi-Key sell them in single quantities), and go from DC to 2.5 kHz. They are smaller, too.
The three models have different noise, sensitivity and range, though. Which would be best for this application?
Part#   Range Sensitivity Noise Density (ug/rtHz)ADXL320 ±5g   174 mV/g    250ADXL321 ±18   57 mV/g     320ADXL322 ±2g   420 mV/g    220
Apr 9, 2007. 9:32 AMendolith says:
And "cheaper" is an understatement, since the minimum order for the Knowles accelerometers is $19,925. :-)
Apr 9, 2007. 9:30 AMendolith says:
Yes, but if they were mounted perpendicular to the microphone, in the correct orientation, which would be the most correct for this application? I'm not an expert on accelerometers and their specs, in other words.
Just guess at the maximum acceleration that would ever be seen on the surface of a wildly moving arm and get one that can measure that much? Go for the one with the greatest sensitivity? I don't know what's important for this.
Apr 9, 2007. 11:02 AMendolith says:
I would go for sensitivity and noise. The ADXL322 seems to be best.
Excellent. Thanks.
There's also the ADXL330 for an application that requires the chip to be mounted parallel to a PCB (though the Analog chips are only 4 mm wide, so the height in perpendicular orientation isn't a big deal):
Part#   Range Sensitivity Noise Density (ug/rtHz)ADXL320 ±5g   174 mV/g    250ADXL321 ±18   57 mV/g     320ADXL322 ±2g   420 mV/g    220ADXL330 ±3.6g 300 mV/g    280
It has three axes (with Z perpendicular to the package surface) but is less than a third of the price of the Knowles (one for $9.99 Newark or $11.58 Digi-Key), so the extra axes aren't costing anything. I think I'll get some of these and see what I can do with them.
Might also find it helpful to combine vibration information from the other axes anyway? I'm not sure if there's a direct relationship between the vibration signal and the microphone signal, or if you're just using the time-averaged amplitude of vibration to ignore microphone signals during that period. I guess I should read through the thesis more carefully. :-)
I just found another page with a bunch of acc that may be useful too.
Ok. They look kind of big. Here are some other companies that make ones that can be bought through Digi-Key:
Analog Devices
VTI
Freescale
ST
Mar 31, 2007. 10:07 AMendolith says:
Do you really need a circuit board to attach three SMT components? Why not just solder them directly to the component leads? It would be cheaper and smaller. If the board is needed for some kind of mechanical structure or acoustic baffling or something, why not just a piece of standard prototyping board? That would be cheaper and easier than creating a custom board for such a simple circuit.
Mar 31, 2007. 11:20 AMendolith says:
These "surfboards" (not a very useful term for search engines) are like perfboards but for surface mount components. I'm sure there are even more appropriate prototyping boards for surface mount components, but I can't find them right now.
Mar 31, 2007. 9:51 AMendolith says:
It would be good if you could list typical prices here, and acceptable part substitutes.
Mar 10, 2007. 8:18 AMjfk says:
Operon - Thanks for putting this together. We've been thinking for a while that MMG might be a low cost alternative for UE prosthetics. We'll have to add building some of these and trying them out to our list of stuff to do. Jon Kuniholm Shared Design Alliance/Open Prosthetics Project
Feb 14, 2007. 7:13 PMsumguysr says:
mind explaining just what the accelorometer does?
Feb 14, 2007. 9:35 PMCrash2108 says:
Measures acceleration.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:Operon
