Mechanical Bull for Dolls
Introduction: Mechanical Bull for Dolls
This mechanical bull was created as a weekend hobby. The creation process was simple and did not last more than two hours. The materials I already had at home. For those who wish to make an equal, will be a good opportunity to recycle materials and learn how to use the joystick shield with Arduino. Hope you enjoy.
Step 1: Materials:
- A volunteer (doll)
- Pieces of cardboard
- An empty soft drink
- Two servomotors
- A Arduino Uno
- A Joystic Shield
- Arms for the servants
- Three screws
- nuts and a washers
- Hot glue, scissors, knife, etc. ...
Step 2: Creating the Model
I used a can of soda as a model for the doll bull riding. After that, I drew on the cardboard, cut out the template and glued using hot glue.
Step 3: Joining the Servomotors
The servo motors are fixed on each other as shown, using a piece of cardboard to position them correctly and hot glue.
Step 4: Attaching the Mount
Joining small pieces of cardboard with a hole in the center, was made a bracket to hold the mount in servants.
Step 5: Joining the Servants and the Mount
I used a bolt, a nut and washer to secure the mount in servants, according to the figure.
Also used a piece to make the linking of movement between the servo arm and mount. This part should be a little slack for not hang with the movements.
Step 6: Fixing on a Base
The base was made ​​with a simple cardboard cutout. I made the design of servo arm that controls the base, cut out and pasted it on cardboard with hot glue.
I used a part of the soda can as a handle to hold the puppets up on it.
Step 7: Assembling and Programming the Controller
#include <Servo.h>  // incluindo a biblioteca dos servos
Servo SRx;
Servo SRy;
const int VRx = A0;
const int VRy = A1;
int sensorVRx = 0;
int sensorVRy = 0;
int outputVRx = 0;
int outputVRy = 0;
long tempo_anterior= 0;
long intervalo= 100; //milisegundos
unsigned long tempo_atual;
void setup()
void loop()
  tempo_atual = millis();// o tempo atual é igual ao tempo de funcionamento do uC
  sensorVRx   = analogRead(VRx);
  sensorVRy   = analogRead(VRy);
  outputVRx   = map(sensorVRx, 0, 1023, 0, 180);
  outputVRy   = map(sensorVRy, 0, 1023, 0, 180);
  if(tempo_atual - tempo_anterior > intervalo)// se o tempo atual menos o tempo anterior for maior que o intervalo com que eu quero fazer minha acao
      tempo_anterior = tempo_atual;//tempo anterior recebe o tempo atual
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    hi I love it. I want to ask a question. Will u show joystick controller connections?
    I didnt see it
    I have a gamepad. And ı want to use it. But I didnt use.
    Oops! My mistake! I thought I had put a figure showing the connections. I connected the joystick shield as follows:
    Wires-----------Sensor Shield----------Joystick Shield
    black wire------------ G--------------------- (gate)
    red wire -------------- V--------------------- (5vots)
    gray wire ------------ A0-------------------- (X axis)
    orange wire --------- A1-------------------- (Y axis)
    As soon as I can, I get a better picture.
    This is great! I hope to build something similar for my "Froggy World" amusement park--of course I'll credit you for the concept.
    I like the fact that you used cardboard--it's a great material for models and prototypes; and actually holds up fairly well.
    Thank you! I love using cardboard because it is easy and inexpensive. Your playground is getting very good too. I'm watching. I am proud to know that you're gonna build a toy with the concept that I created. Then show us.
    lol, that is a fun lil' project.
