Introduction: Mechanical Heart
Small box made with polymer clay, with rudimentary mechanism.
You can fill it with love words and offer to someone special!
Step 1:
Materials used in this project:
- Polymer clay
- 2 cookie cutters with 2 different sizes
- fimo liquid
- Epoxy glue
- embossing powder
- head pin
- Ribbon end crimp
- key charm
- paper
- Dimensional paint
- varnish (optional)
Step 2:
Making polymer clay gears with different sizes and shapes
Step 3:
Using a cookie cutter, cut 2 polymer clay hearts
Step 4:
Use the smaller cookie cutter as a mold and cover it with polymer clay.
Leave a small space open
Step 5:
Make a hole on each heart, in the same position
Step 6:
Make a small cylinder. It must be smaller then the height of the heart box.
Insert the head pin
Make a small cutt and insert a piece of paper
Make a small handle for the top
Step 7:
Bake all the pieces in the oven, during 30 minutes at 110°C/230°F
Step 8:
Unmount all the pieces of the head pin and remove the mold of the heart
Is time to start the box construction!
Use one heart as the base
The pieces of the head pin will be our mechanism . Insert the pin on the base.
Inside of the box let's place the cylinder and glue it at the pin
Replace the small piece of paper by a long strip. Glue it at the cylinder and make sure thet it will stay in place before you close the box with the second heart.
Let it dry
I used epoxy glue for all the parts.
Step 9:
Creating the metalic effect on the gears with embossing powder.
I've used fimo liquid as fixative for the embossing powder
Use the heat gun to melt the embossing powder and use something to flat it before it cools down. I used an acrylic block, but you can use a metalic piece too
Step 10:
Time to decorate the box with the gears, using epoxy glue.
The last gear should be placed in the head pin and glued to it
Give an appropriate and functional shape to your handle using the pliers
Step 11:
Before winding the paper strip, make sure that you can pull it of!!
For that I used a ribbon end crimp, with a small key charm
I added a few more decorative details with dimensional paint
And the mechanical heart is ready to use!!
It will make more sense if you write some nice words on the paper strip and give it to someone very special!!
