Mechanical Light Sensing and Flex Sensors Controlled Flower Robot
Introduction: Mechanical Light Sensing and Flex Sensors Controlled Flower Robot
Purpose :
Create a robot that follows light and can move with flex sensors on a glove
This instructable was inspired by :
This instructable was created in fulfillment of the project requirement of the Makecourse at the University of South Florida (
Step 1: Part List
MAKEcourse Kit : get it here
If you do not feel like purchasing the whole kit get the following :
Mechanical :
[ Pack of 5 ] Micro Servos
[ 2 ] Standard Servos
[5+] Ball Bearings { 0.5 inch }
Electrical :
[ 5 ]Flex Sensors
Computer :
Autodesk Inventor 2014 :
free for 3 years - just sign up
Arduino IDE
Step 2: Mechanical Design
Below are the STL files ready to be 3D printed
You could 3D print the brackets, but they need to be edited so they are not as brittle.
I would recommend buying the brackets from amazon.
The specific brackets are :
Short U Bracket :
or :
Long U Bracket :
Oblique Bracket :
Could also buy the kit for other robot projects :
[ Which comes with ball bearings and screws ]
Step 3: Wiring + Electronics
The basic idea is :
The large external battery goes into the step down regulator.
Then the regulator goes to the power rails on the breadboard [ which is the messier looking PCB board you see in picture 8 ].
The servos are connected to the ground and power of the power rail [ supplied by the regulated voltage ].
The signal wires of the servos go into the digital pins of the arduino.
Then , the power and ground for the sensors [ photo resistor + all flex sensors ] comes from the arduino board.
The signal wire for the touch pad goes into one of the digital pins, while the flex sensors are placed into the analog pins [ but not before a resistor is placed in series -- see the spark fun link for more clarity ].
Once the breadboard functions, then buy some PCB [ like this type ] and you are set.
Here is a similar project which did a very good job at showing the wiring for the photo-resistors and servos :
Fritzing Image + Wiring Clarifying :
Step 4: Code
The Code is well commented but here are things to keep in mind :
  • The comparison [ line 96 ] can change depending on the light you apply to the photo resistor and ambient light settings.
  • [Line 162] : the range for each flex sensor is different, so change the first two numbers to get a better resolution. Also, the servos are contrained from 70 to 110 degrees because of clearance issues and a smoother operation.
  • [Line 253] : Included to make sure the touchpad works before wiring everything.
Here is a good, shortened example of the flex-sensor code using serial print to see the values [ change 0 to 100 ]
Or : Using 1 servo
Step 5: Conclusion (with Video and More Pictures)
Thank you for viewing my instructable.
Finally, I would like to thank the following people for helping me make this project possible:
Dr. Rudy Schlaff
Eric Tridas
Sergei Dines
Dominic Cox
If you have anymore questions , feel free to message me.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    well done nice project it's nice to see young persons put up on instructables projects of this type and not just a photo or two with no instructions on how it was made
    thank you
    Very nicely done! Great first project, too.
    Welcome to instructables!
    Thank you for taking your time to view and comment on my project!
