You'll need some magnets -preferably of the same size, type and somewhat strong (weak magnets do not work as effectivly). You're also going to need some ball bearings that show visible reactions in magnetic fields (aka nickel, coblat and iron/ferrous steel).
You're also going to need a ruler or some sort of straight edge. Movie on next step ;)
Remove these ads by
Signing UpStep 1Setup and Demonstration
Place one magnet on one ball - then place the ball on your straight edge. Attach to the ball (but not to the magnet), one or two additional balls. You can stop here - or repeat this as many times as you want/can.
Take a different ball - and roll it towards the magnet on the first collection of magnet/balls. You should notice that once the ball is inside the magnetic field, it accelerates towards the magnet and makes contact with the magnet/ball cluster. Once contact is made, the last ball(s) separate in the same direction as the original ball.
This phenomina demonstrates the concept of conservation of momentum. If you were to repeat this demonstration without the magnets, you will have the same results with less motion.
The rest of this instructable has more information/examples for those that want to know more.
rail_gun.mov1 MB| « Previous Step | Download PDFView All Steps | Next Step » |
The moon, on the other hand, is slowly being pushed away from Earth. About 4cm per year resulting in Earth's rotation slowing about 2 seconds every 100,000 years due to tidal forces and tidal locking (same reason we only see one side of the moon).
Satellites experience significant orbital decay as their mass is much smaller compared to Earth's mass and their distance is EXTREMELY close. Small forces due to atmospheric particles have large consequences over time.
The Earth, Sun and Moon are in motion, but their motion is not perpetual.
The Earth happens to be travelling through a vacuum - there really isn't much that will slow it down but things do. Meteorite strikes, technically, are forces on Earth. Earth has several orders of magnitude more mass - this is like throwing a grain of sand at a cannon ball. Sure, the grain of sand applies a force, but it's imperceptible. Other than meteors, nearby asteroids and other celestial bodies will exert nonzero gravitational forces - Earth is still much larger - so large that it's irrelevant here...
To note: Earth is slowly moving away from the Sun - about 15cm per year. Slowly, we're stealing angular momentum from the Sun so that we may move into a higher orbit. On a human scale, this orbit is forever and perpetual. For the rate at which this occurs, the Earth will be swallowed by the Sun long before there's any orbit issue.
put in a vacuum and push it and see how long the pendulum moves!
Initial kinetic energy of ball from last stage + X joules stored in current stage - friction losses = more kinetic energy transferred to ball exiting stage
thus sustaining the reaction for an infinate number of stages in a row. What will eventually fizzle out is the acceleration, as it reaches a steady state. After a point, the same X joules added by the stage will be required to overcome the increased friction forces, and all successive stages will fire at a constant velocity. However, they will STILL FIRE in a line of stages that extends to infinity.
Assuming no friction and infinately strong magnet/ball materials, the acceleration would continue, but the balls would smash at a certain velocity. In fact, this is probably what would happen if you built a long enough train in real life - a shattered magnet would stop it long before it reached a steady state.
However, with respects to perpetual motion and the circle, after firing, the stage has expended its stored energy to accelerate the ball, and cannot fire again without you setting it back to the initial state (and thus expending energy to do so). Perpetual motion guys, energy's gotta come from somewhere! In this case - it's your hand.
Welcome to this thread... Allow me to introduce you to the subject:
What changes would need to be implemented to keep this going in a loop?
It's really not air causing resistance.... at least, it's not the biggest factor. It's the inelastic collision. The fact you hear sound means that the steel is vibrating. Vibration is a loss of power (pretty much turned into heat) :p
