3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mechanized Android Figure
These Android figures are cute, but they don't actually do anything. Let's change that. Have a look at the video:
These are the steps to make an Android that reacts to sound, moves it's head, sends out Morse Code messages and displays some cool light patterns. In the video the LEDs in the body are not that visible, but this is what it looks like:
Step 1Parts and Schematics
These are the required parts:
1 x Android Figure from DYZPLASTIC
1 x ATtiny44A from Mouser or Digikey
1 x 14 pin DIL socket e.g. from Digikey
1 x Micro Servo SG90 (plastic) or MG90S (metal)
1 x Microphone e.g. CMC-5042PF-AC from Digikey
1 x Piezo (passive, not the buzzer kind)
2 x blue 5mm flat top wide angle LED from ebay
1 x red super bright 5mm LED
1 x green super bright 5mm LED
1 x yellow super bright 5mm LED
1 x NPN Transistor e.g. 2N3904 from Digikey
2 x Rectifier e.g.  1N4003 e.g. from Digikey
1 x 100uF electrolytic capacitor
3 x 100nF ceramic capacitor
2 x 100K resistor
2 x 10K resistor
2 x 2K2 resistor (or other values depending on your blue LEDs)
3 x 150 resistor
1 x +5V power supply (e.g. USB charger)
There are many different versions of the Android figure. If you want to have LEDs inside the body, it is probably best to choose a light colored Android. Darker ones might block the light  shining through too much.
For the eyes I used super bright wide angle 5mm flat top LEDs. They are actually too bright, so I used some larger resistor values to adjust for that. Try different values until the maximum brightness is to your liking.
I used a Mystery SD90 servo with plastic geras. After 2 months of heavy use it wore out. I have now replaced it with a T-Pro MG90S which has metal gears. It is more noisy, but hopefully that one will last.
A +5V USB phone charger makes a nice power supply.
To program the ATtiny44A micro controller you can either use an official Atmel programmer like the  AVRISP mkII or one of the many third party programmers.
74 comments
1-40 of 74next »
Nov 27, 2011. 8:38 AMboot-cheese-3000 says:
i love this tutorial and the others based on this. i was planning on making some as Christmas presents. i was thinking of using this tutorial and Hitmit's as well since his is pretty cool. one thing is that the servos he uses for the arm were too big for the toy but i saw that you didn't have that problem in your videos, the Android's arms move so freely without having a section of the body cut out and exposing part of the servo. what type of servos did you use? i want to leave room in for blinking LEDs in the eyes if not the body so it can blink while it dances so what would be the best servos for this to happen?
Nov 13, 2011. 8:54 AMrlebel says:
I love it but i would like a how to that shows how to get the arms and body moving too. this would be my first robot but i am thinking about if i can do the arms and body myself.
Aug 2, 2011. 11:27 AMpobturtle says:
about how much do the parts cost in total???
Nov 13, 2011. 8:42 AMrlebel says:
I was wondering the same thing so I looked into it took me like 5 mins you should try it.
Aug 21, 2011. 6:18 PMtheswordninja561 says:
........ have a alarm around them in your room at night...
Jul 28, 2011. 6:52 AMelectrodaktylus says:
Thank you for such a great and fun Instructable!
The head of my android is having difficulties moving because the wires that I used are too stiff, but I love him anyways. Maybe one day Ill open it again and rewire him with softer cables.
Jul 16, 2011. 8:56 AMsirius00 says:
I uploaded the video on youtube
http://www.youtube.com/watch?v=x5d2GzrK36M
Jul 12, 2011. 3:13 PMdaman92 says:
First, Thank you for the schematics and instructions. Does any one have any specs on the Piezo or a part number/location to find one. I'm buying the parts for this project and am having trouble finding a "passive" one. I am new to this, but there are a lot of Piezos out there, so any help is welcome. Thanks in advance.
Jul 13, 2011. 3:04 PMdaman92 says:
Thank you for the quick reply! I'll try that out and let you know how it goes.
Jul 10, 2011. 5:15 AMsirius00 says:
Hello,
I was able to program the chip, with the information you have given me, I am sending you the photo, best regads ,
Andy
Jul 6, 2011. 12:12 PMsirius00 says:
compliments for android, I finally received four AVRStudio avrispmkii with software, I have never used this software, how do I set the fuse not to burn everything? What is the exact procedure to program ATTINY44? Frequency isp?, Internal oscillator? Many thanks for your help. I can not wait to get it working.
May 23, 2011. 9:41 PMbwilly says:
Great instructable! All my other electronic projects have been put on hold thanks to this! Have been having lots of fun putting it together. I'm still on the breadboarding phase. Have the microcontroller programmed and the piezo and lights are working just fine. I don't seem to be able to get the triggering part of the circuit working and was wondering what the best way was to test this. The microphone doesn't seem to do much. If pin 13 of the microcontroller gets anything but ground, it causes the piezo to sound off in morse code. I tried hooking up a logic probe as a way to test - hoping to get a value of high when I yell into the microphone but it always stays low. Any suggestions you have for debugging this part of the circuit would be greatly appreciated. By the way... I have been using an electret microphone from sparkfun (sku: com-08635) but as far as I can tell is it nearly identical to the one from Digikey.
May 24, 2011. 8:24 PMbwilly says:
Thanks for your speedy reply. I don't have an oscilloscope as yet but actually do have one on order that I hope to get soon. I used a digital probe on the positive side of the microphone hoping that I would see some change when I made a noise but perhaps that isn't a good test. I did measure the voltage across the two pins on the microphone and am getting a reading of about 3.10 volts. I'm pretty sure the transistor is hooked up correctly - I tested it in a circuit using it as a switch to light an led. I didn't realize that the circuit attached to pin 13 was for amplification so maybe I will try the sparkfun board to see what happens. I happen to have ordered the Op-Amp breakout (BOB-09816) so am thinking that I could try this in place of that circuit. - feeding the output to pin 13. I can make the speaker and servo go off when I remove the connection from pin 13 - is that normal? If you can think of any other methods that I could use t breakdown the circuit further for testing, that would be very helpful. Thanks!
Apr 2, 2011. 9:23 AMFoaly says:
Amazing instructable, but i failed trying to upload code on the attiny. Could you post a photo of the other side of the circuit please?
Thanks
Apr 3, 2011. 6:38 AMFoaly says:
Thank you, I'm sure this will help other people too. I now have confirmation that the way I wired the attiny was right, but it still doesn't want to enter in programmation mode. May be I fried it while trying to make it work.
My programmer is an Olimex AVR-ISP500-TINY, and I only have a 10-pins cable, but it should work fine right? (I didn't understand why there is a 10-pins ISP besides the 6, since 4 of them are GND or NC...)
Apr 18, 2011. 8:25 AMFoaly says:
Ok it works now. I just received a cheap USBASP programmer (from ebay : http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=270718688454), and I managed to get it work with avrdude. Thanks again for your answers, and hope this could help other people!
May 23, 2011. 3:54 PM3volution says:
I got the same programmer, but not sure how the circuit diagram works since the cable is 10pin. Is the RXD and TXD goto ground? and NC you don't connect to anything right?
May 24, 2011. 8:09 AMFoaly says:
If you have the same programmer, look at this (the right one) : http://www.elechouse.com/elechouse/images/product/Atmel%20AVRISP%20STK500%20USB%20ISP%20Programmer/avr_isp.jpg
This should be the map but at the programmer output, so the 2 columns should be flipped at the end of the cable.
My advice : plug your programmer in with the cable but no avr, put a voltmeter (some breadboard wires are useful) at what you think is pin 2 on this image (+) and 10 (-), you should see +5V. If 0v, you are testing 1-9 or 9-1, and if you have -5V, you have 10 on (+) and 2 on (-).
Then the image give you the other pins.
Sorry if this message is not very clear, I do what I can with my poor english ^^ Hope you understand anyway, else let me know.
May 24, 2011. 10:48 AM3volution says:
The link doesn't work for me for some reason. The programmer I got is the ebay link you posted.
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=270718688454&ssPageName=STRK:MEWAX:IT#ht_1742wt_905
This is the same one you got right? just to make sure.
May 24, 2011. 10:50 AM3volution says:
The schematic im looking at was provided by the seller of the programmer. Here is a link to the schematic
http://www.yourportablelab.com/downloads/schematics/USBASP2_SCH.pdf
Im looking at the most upper left portion of the image labelled "ISP". Is this the correct part to be looking at for the 10 pin cable?
May 24, 2011. 11:16 AMFoaly says:
Yep it's the same programmer, and exactly the same schematic (the other was just the first image i found on google)
Do the woltmeter thing to ensure you have the correct pins, then draw yourself something to remember. You should have the same as me : when you look at the pins of the cable, with the plastic thing at the left (besides the pin 5), the positions are the same as the schematic.
May 24, 2011. 11:25 AM3volution says:
umm not really sure what you mean, but ill give it a try. But I still don't know what to do with the TXD and RXD (Pin 4 and 6 respectively)?
May 24, 2011. 12:24 PM3volution says:
So i did the voltage test. For,
Pin 2 (+) and Pin 10 (-) i got +5V
Pin 2 (-) and Pin 10 (+) i got -5V
This makes sense since pin 10 is GND.
Pin 1 and Pin 9 i got 0V
Pin 2 (+) and Pin 8 (-) i got +5V which makes sense since Pin 8 is GND as well
Pin 2 (+) and Pin 6-RXD (-) i got +5V, so does that mean RXD goes to GND as well?
however,
Pin 2 (+) and Pin 4-TXD (-) i got 0V, so does that mean TXD does NOT goto ground?
not sure what im doing since im new to this stuff. But is any of this correct? Thanks
May 24, 2011. 1:00 PMFoaly says:
I didn't noticed the TXD and RXD on your scheme, on mine it is noted GND. What is important is what you called pin 2 on your cable : you know this is VCC. Be careful, {1,3,5,7,9} and {2,4,6,8,10} may be flipped since you are seeing the cable from the other side.
I took a photo of mine (hope you can see it) :
http://imageshack.us/photo/my-images/836/imag0313x.jpg/
The red pin is VCC, the numbers are the same as on your scheme.
If you plug your Atmel this way (VCC on 2, GND on 10, then MOSI/MISO/SCK/RST), it should work.
No problem, I'm new too, I just had a hard time making it work, so I hope the results of all the things I tried could help someone else :)
May 30, 2011. 8:44 PM3volution says:
I checked to make sure I had the pins in the correct order. I try programming it with AVRDude and got an error of "cannot set sck period", but it read 100% then wrote 100% then read again 100%. so does that mean it worked? haven't go the rest of my components yet so I haven't tested it yet.
May 31, 2011. 8:43 AMFoaly says:
Yes, I get this warning too, but the chip should work perfectly.
May 31, 2011. 2:22 PM3volution says:
Thanks alot for your help both of you, Foaly and tanabata. Once im finish ill let you know how it goes.
Jun 1, 2011. 12:09 PM3volution says:
So i put everything together and i have a problem. the lights and piezo seem to work but the servo doesn't do anything. I'm guessing I wired something wrong? what can i do to check this? any advice?
Apr 4, 2011. 9:54 AMFoaly says:
Yep I tried reversing them, with exactely no effect. I don't know if this is the latest fw, but since it's not mine (I borrowed it from my school), I don't want to try... (Apparently it's a pretty expensive gadget).
I'll try another time this evening, but I have to give it back tomorrow.
Thanks for your help anyway; I'll try another way, maybe with my arduino.
May 5, 2011. 1:32 PMsirius00 says:
Compliments for the gadget, I with AVRStudio I can not convert the file.asm.in hex to program the chip. You can send by mail? Thanks
May 19, 2011. 12:43 PMsirius00 says:
many thanks, I have prepared all the electronics, I'm waiting the micro servo, when I finished the Android will send you the photo
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:tanabata
