Media Cabinet
Introduction: Media Cabinet
Inspired by Crate and Barrel designs, I decided to build me one very affordable Media cabinet.
@ C&B they use it as a space divider. It could fit many purposes and yet stand solid and strong!
For this project You would need
  • 7 x 2Mx30CM Wood Shelfs (Pine or Oak - depending on Budget )
  • 2 x 2Mx4cCM Flat Metal Bars
  • Electric Drill
  • Wood Screws
  • Chisels 2,3,4 CM
  • Wood filer
  • Wood Saw
  • Angle Ruler
  • Pencil
  • Wood Hammer (Or a Hammer with Rubber head)
  • Good Energy :) & Music
Paint can be an option, however we decided to keep it in natural wood color.
Step 1: Making the Dovetails
First I had to cut the Shelves to 120CMx30CM(A) each and keep 36CMx30CM(B) for the Edges. That can easily be ordered or cut using a table saw.
In order to make the edges more interesting, I decided to make them in dovetails instead of just gluing or screwing them together.
The main steps are to
  1. Mark the edges of the A and make the cuts (Using the angle ruler, you may choose an angle of your liking)
  2. Place B in a 90 degree angle on A and mark the rest of the puzzle.
  3. After a lot of cutting, the edges should fit in.
In order to have a clean cut, use the Chisels and hammer it down slowly removing any extra wood every now and then. This step requires a lot of patience and endurance. Good luck.
An easy tutorial that helped me a lot was the below.
Step 2: Building the Puzzle
On a table or the floor, I tried to build in the puzzle.
I decided to test the shape and see how correct my angles were.
This step is just a quality control step were I identified the edges that needed more smoothing and the exact adjustments. A wooden filer was needed.
Step 3: Installing the Flat Bars
In order to have a smooth finish, I decided to make groves into the shelves so the metal bars would fit exactly in.
With a pencil I marked 15CM away from the edge a 4CMx2CM rectangle.
  1. With the Wood Hand Saw I made the 2CM cuts
  2. then with the Chisel and hammer it was a very easy task to cut thru the wood.
Some smoothing was needed using a wood filer
After all the groves are made, Using the electric drill, I made the necessarry holes into the metal rods based on the 36CM distances between each shelf.
Note: I made them 36CM since we are using 33 Disks in our turn table and we needed the extra room for additional art books.
Once all was screwed in, I had to put the backside. I used a drill and wooden screws to attach the backside to the shelves.
I prefer to drill the wood before using the screws in order to avoid unnecessary cracks in the wood.
Step 4: Making Sure It Stands & Filling It Up.
After sometime left on the floor, I made sure that the wood had already taken the correct shape and was ready to stand.
In order to hide all the electrical cables (as much as I could ;P ) I made 3CM holes into the back board on the levels where power cables, speaker cables and network cables needed to pass.
In this setup there is a special Airplay receiver using raspberry pi (I will post a project on that soon) that I added to the old school amplifier. Now we can airplay our music as well as listen to records from the 30s on the same amp and high quality speakers.
I apologize if I don't have documented photos or videos since I made this project a while back and didn't properly document it for a publication. I will be open to your questions if you are interested in such a piece for your living.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Great job! Would you have the website for the beacket
    Thank you. Not sure what you are asking about though? The little toy elephant is my daughters :).
