Mediatek LinkIT One Setting Up TING for GSM and GPRS
Published
Introduction: Mediatek LinkIT One Setting Up TING for GSM and GPRS
Next in my of LinkIT One projects.
This is how to setup the TING pay as you use simcard with the MediaTek LinkIT One
Here is my Ting referral code if you want to sign up for Ting if you use this link i will get some cash: https://zki47f482jc.ting.com/
Step 1: Parts
The parts used here are:
Mediatek LinkIT One: http://www.seeedstudio.com/depot/LinkIt-ONE-p-201...
Adafruit RGB LCD shied: https://www.adafruit.com/products/714
TING GSM simcard. here is my referral code for TING: https://zki47f482jc.ting.com/
The MediaTek LinkIT One is an amazing board with loads of power, memory etc... but where it really stands out are its "sensors" this thing has GPS, GPRS,GSM,Bluetooth, Wifi and Lipo charging and monitoring on board along with being arduino compatible.
The Adafruit LCd backback is really cool. it allows you to add a screen and 5 buttons to any i2c compatible board using only 4 wires, i2c (2 wires) and power and ground. this makes it very easy to work with and add on to a project like this.
Ting is a pay as you use sim card with data, voice and SMS plans.
Step 2: Code
Here is the code,
its the test code that comes with the MediaKit LinkIt One.
it is a call test.
Step 3: Ting Setup
Goto
https://ting.com/go/devices
To start the activation process.
Step 1 is entering in the imei of the device to verify it will work.
Step 2 is entering in the sim card numbers.
Step 3 is setting a phone number,
Step 4 is verification
and then you are done!
Step 4: The Board
The only thing you need to do for the board is power off the board then put the sim in it.
It takes a standard sized sim and it goes in bottom down.
Load up the code and give it a test!
thanks for reading!!
Raptor
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
