Medieval Minecraft Ground House
Introduction: Medieval Minecraft Ground House
Its a medieval style mine craft house IN TH GROUND.
Step 1: Supplies
  • oak logs
  • oak planks
  • oak half slabs
  • oak steps
  • stone brick steps
  • cobble stone
  • a door
  • ladder
  • glass
  • torches
  • pressure plate
  • bed
  • fence
  • iron bars
optional (john smiths texture pack) if you want it to look nice like mine.
Step 2: Make the Base
The hole should be two blocks deep with logs in the corners and stone between them as shown in the pictures. the doorway should have a log on its side over the door as shown. Above the ground you will need to bring the logs up two and the wood blocks up one.
Step 3: The Roof
The roof should go around the walls in a circle its hard to explain so just follow the pictures. Same goes for the windows areas you can use ether use glass blocks or use glass pains. At this point you can add the stair case down to the house.
Step 4: Interior Design
In this step you can start by making the loft
and then you can make it look like the last picture with the house all decked out.
Step 5: Chimney
The chimney is pretty simple and you use a torch for the light because if you use fire and nether rack the house will catch on fire (trust me i know)
The chimney will go next to the wall the the left as you walk in. you will need to tear out those three pillars of blocks to put the chimney in.
the chimney in my opinion make this house awesome and its you chose to put ether stone brick stairs or cobble stone stairs on the chimney.
Step 6: Finished
Now your done unless you want to add some cobwebs on the chimney for smoke or add a bush or two to make it look more natural.
If you would like to see more of these mine craft house tutorials please let me know and i will get right on it.
    • Trash to Treasure
      Trash to Treasure
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    I have plenty of other house designs and if wanted I can try to do some modern houses.
    Hey man. We'll done . I would love to see some more minecraft house tutorials ( only cool houses) .
