3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mega Man Costume
Step 8Mega Man's Mega Buster (Form Body)
Mega Man\
Tools:
Saw
Utility Knife
Curved Hobby Scissors
Dremel
Materials:
Small pitcher (tappered)
One Medium Bowl
Two Small Bowls
Two Extra Small Bowls
Sand Paper
The pitcher I got was lined with another container inside. I sawed off the handle (but was keeping it for something later in the build). Then I cut the liner container out of the pitcher, and the pitchers bottom off.
Since I like the stylized look of the Mega Buster, I wanted the gun tip to be a little fatter thus using the opening of the pitcher on that end. The thinner side of the pitcher went towards my sons elbow. I took one small bowl and cut the top off so that it sat flush with the cut opening on the pitcher. I then too that same small tupperware and cut the bottom off so that it hugs my sons forearm. I then took the medium sized bowl and cut out the bottom curve of it so that it would finish off the gun tip edge nicely. I cut the bottom out of that same medium bowl so the gun top could protrude through. Then I cut a small bowl to fit inside/stick out of the medium bowl thus creating the gun tip. Cut the bottom out of that small bowl to open up the barrel of the gun. Then cut the top off of extra small bowl to fit in the barrel of the gun(leaving the bottom in tack for mounting an LED!!!). The took another extra small bowl and cut off the bottom to use as a cover. See pictures below for all of these pieces.
All those steps took a really long time to cut down so they would all fit just right with each other.
I then took the pitcher and cut a rectangle into it with the dremel for the power meter (Yeah, we are going to put MORE LED's in this thing!). Dremeled down the handle that I had cut off the pitcher so that it could hold the LED's for the power meter. Finally I cut a thin piece of plastic that will be used to cover the hole for the power meter.
I then cut down a plastic pen that would fit inside the pitcher that would act as a handle for my son to hold on to. Finally, I sanded down all the rough edges and smoothed it all out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:craineum(Twitter)
