Introduction: Mega Prusa I3
The Prusa Titan concept was first introduced by the company named BluePrinted.com.au on October 8 2014, however to this day the company did not publish the blueprint's for the build of the large Prusa i3 3D printer.
Because i found the concept very interesting i took the liberty of sharing my version called Mega Prusa i3 Rework. The Mega Prusa i3 rework is basically an enlarged version of the Prusa i3 Rework. Is is scaled up from the original design. To be more precise, the Mega Prusa i3 Rewrk is scaled um in order to allow 8 times the build volume of the Prusa i3 Rework, a stunning 400x400x400mm.
Step 1: Photos of Builds and Upgrades
Here are some photos of some builds of the Mega Prusa i3, made by some members of the instructables community.
For more info on upgrades please visit (stormychel designs):
http://www.thingiverse.com/stormychel/designs
Some very us-full comments/upgrades made by sinstructable user named stormychel:
1 - Do not use the resistors to heat the bed, get a silicone heater here : http://alirubber.en.alibaba.com/product/192571649...
2 - You need an extruder : http://www.thingiverse.com/thing:65939
3 - My version of the frame : http://www.thingiverse.com/thing:65939
4 - Use my Y-belt holder instead of the original one : http://www.thingiverse.com/thing:65939
5 - Also print these to shim out the extruder to fit the modified X-carriage : http://www.thingiverse.com/thing:65939
6 - Use my Z-endstop here with Sainsmart endstops (these might require gentle bending to be able to get to the mounting holes, this also counts for the X and Y ones : http://www.thingiverse.com/thing:65939
7 - Here's a spool stand I modified to fit the 9mm MDF frame : http://www.thingiverse.com/thing:65939
Step 2: Open Source RepRap Design
The Mega Prusa i3 Rework by reprapalgarve is just a scaled up version of the Prusa i3 rework 3D printer. Most of the 3d Printed parts where redesigned in order to house the LM12UU Bearings and the 12mm smooth rods.
Because the Mega Prusa i3 is has a big and heavier structure 8mm rods don't work, so for that reason 12mm rods where used.
Use this sketchup file as a guideline for your build.
For more information on the Prusa i3 rework please visit the official reprap source here:
Step 3: Bill of Materials
Here is the list of material needed to build a Mega Prusa i3 Rework, tey are very similar to the Prusa i3 rework.
- Rods
4 Smooth Rod Ø12 740 mm
2 Smooth rod Ø12 540 mm
2 Smooth rod Ø12 600 mm
2 Threaded rod M5 520 mm
4 Threaded rod M10 770 mm
4 Threaded rod M10 430 mm
- Mechanical Parts
14 Linear Bearing LM12UU
1 Bearing 624
4 Bearing 608
1 Belt GT2 1400 mm
1 Belt GT2 1400 mm
2 Coupling 5*5
5 Motor Nema 17
2 Pulley GT2
- Heated bed
1 Aluminium plate 450x450x3mm
1 Glass Plate 450x400x3mm
1 Kapton Tape
8 Binder Clip
1 Thermistor
- Electronics
1 RAMPS Board
1 Arduino Mega 2560
4 Micro stepping Drivers
3 Endstop w/ cables
1 Power supply w/ cables
- Screws, nuts and washers
41 Screw M3 14
3 Screw M3 24
4 Screw M3 50
2 Screw M3 60
6 Screw M4 20
1 Screw M8 30
53 Washer Ø3 mm
6 Washer Ø8 mm
54 Washer Ø10 mm
1 Grub Screw M8 20
5 Grub Screw M3 8
33 Nut M3
6 Nut M4
2 Nut M5
1 Nut M8
54 Nut M10
1 Nylstop Nut M8
Acrylic Frame
1 Single frame with back support
1 Heated bed mount
Step 4: Cutting the Smooth and Threaded Rods
Tools :
- Grinding wheel
- Full Face Mask and gloves
- Grinder
- Pencil and ruler
Instructions:
Using the pencil and ruler mark the cutting lengths on the rods. Using a grinding wheel cut the rods and according to size. After cutting grind the extremities of the rods for a sooth finish.
2 Smooth Rod Ø12 740 mm
4 Threaded rod M10 760 mm
Step 5: Acrylic Frame - CNC Mill or Laser Cut
Tools:
- CNC machine or Laser cutter
Materials:
- 600x600x10mm acrylic sheet
- Acrylic glue
Instructions: After cutting the acrylic glue the rear part of the frame for extra support.
Step 6: The Y Axis Guide and Transmission System
Mount the Base of the Mega Prusa i3 Rework according to the Skechup design.
Step 7: The X Axis Guide and Transmission System
Mount the Vertical frame of the Mega Prusa i3 Rework according to the Skechup design.
Note that the photos on this step show 8mm smooth rods instead of 12mm, 8mm rods don't work, they do not have enough strength to support the structures in place.
Step 8: The Z Axis Guide and Transmission System
Mount the Z axis of the Mega Prusa i3 Rework according to the Skechup design.
Step 9: The Electronics
Wire the electronics according to the wires on the schematic, with the exception of the heat bed.
Step 10: The Aluminium Heat Bed
Fist i tried to connect 4 heat-beds together but eventually found a more cost efficient way to do it using resistors.
The Heat bed is made from a 450x450x3mm aluminum plate. It has 4 10W resistors 4.7 Ohm in parallel connected to the Ramps D8 connector.
Each resistor has 2 holes for fixating on the plate using screws.
Instructions:
- Tap 4mm threaded screw holes in the aluminum plate (for fixating the resistors)
- Fixate the resistors in place using M4 bolts
- Connect all 4 resistors in Parallel
Step 11: Mega Prusa I3 Rework Vs Normal Prusa I3 Rework
Prusa i3 rework
- Build volume 200x200x200mm
- Build volume 400x400x400mm
Step 12: The Final Results
The Mega Prusa i3 Rework is a excellent machine to have in your arsenal of 3D printers :) because of its large build volume and because it is easy to build.
First Prize in the
CNC Challenge
Tools Contest
Guerilla Design Contest
