Melody Box
218
Posted in TechnologyArduino
Introduction: Melody Box
Hello there!
I made a box that has 3 buttons with each a different melody.
Each melody has a different LED color and goes on when a note is being played.
Whenever you push the "forward" button the melody is going faster.
The things you need:
- 1x Buzzer
- 3x LEDS
- 1x Force sensitive
- 6x 220ohm Resistors
Step 1: Breadbord
If you put everything as in the picture, you should be good to go and move on to the code!
Step 2: The Code
Download the text file and you will see my code I used.
Add a tab called pitches.h and copy paste the notes
Step 3: Building !
I used a small box because I needed to get this thing all the way to my school (cycling, train, etc) but you can choose whatever box you like ;)
Put the buttons on top of the box and soldered them. I used glue for the LEDS because I used long wires with an input wires. I also used these wires to connect the Buzzer to put it on top of the box as well.
Then you make a hole on the side of the box so you can use the USB for the Arduino UNO.
(Don't forget to glue/tape the Breaboard and Arduino, or they will move around too much inside the box)
Now you can close the box :)
Step 4: Decoration
Now you can decorate your box!
I drew 1, 2 and 3 for the buttons and the >> icon for forward.
And I drew BB8 as an icon for the 1rst button, The Ring icon for the 2nd and a piano icon for the 3rd.
Now you're finished. Enjoy! :D
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    This could be really fun to use like a sound effects machine :)
