3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Melt and Pour Soap Making - Home Made Soap the Easy Way
This is a great way to make 'home made' soap as presents for friends and family. All the information you need to get started is around on the internet, but tends to be a little scattered. I taught myself to do this about a year ago when I wanted to make presents for Christmas rather than simply buying them. I enjoyed it so much I continued learning and experimenting, and decided to share my techniques and tips in an instructible.
I will start with the absolute basics, then include a few more ideas later on. If you already make soap and are just looking for new ideas, you might want to skim over the basics and head to the end!
Just a note: Melt and pour soap could be considered a 'cheat's' way of making soap, as you purchase pre-made soap base, melt it and add things to it. I like it because it is ideal for a small kitchen, very forgiving and easy to be creative with. It would be an ideal project for kids, though under supervision only - the molten soap can get very hot, and before melting it usually needs to be cut up with a knife, so please be careful!
An inventive example of what you could do with M&P soap can be found here.
Step 1Gather ingredients and equipment.
You will need:
Ingredients
Melt and pour soap base, either clear or opaque, or both - I tend to get mine in very big blocks on ebay. Beware, it must be M&P soap base, most ordinary soap won't melt. I learned this the hard way so you wouldn't have to!
Soap colouring - ebay again. Be sure to get the water soluble colours if you are using clear soap.
*There are several specialist soap making shops online - so far ebay has always been cheapest for the soap base and colouring. You might find things cheaper elsewhere if you are prepared to shop around a bit. *
Cosmetic grade scent or essential oils - I buy essential oils from places like health food shops. Soap making sites stock special scents but essential oils are cheaper and more natural!
Surgical spirits - try your pharmacy, I got mine from Superdrug. I believe it is known as rubbing alcohol in the US. I have also read that you could substitute witch hazel, though I haven't tried it.
Equipment
A microwave - You could do this in a double boiler on the stove if necessary, but that would be a nuisance!
Microwave safe container to melt the soap - I picked up a couple of microwave pots on sale in a local thrift store for about a pound. A microwaveable plastic or glass jug works well too. You really want that pouring spout!
Something to stir with - I used some pieces of dowel rod we had lying around.
A small spray bottle - try the travel section of your pharmacy. I got mine from Superdrug.
A mould - this needn't be a specialist soap mould, though there are plenty of them available on ebay and soap making sites. Any reasonably flexible container will do, as long as it won't melt too easily! Think cream cheese tubs, yoghurt containers, silicone ice cube trays etc.
Cling film - This soap does not like being exposed to the air, so wrap it fairly soon after it has set.
A chopping board and knife, or a grater - chopping or grating the soap base helps it melt .
A scale - this becomes less necessary as you learn to measure by eye.
If you buy the powdered colourant, you will also need some small dropper bottles (pharmacy again) and other small containers such as plastic shot glasses to mix it all up in.
Some people are fussy about not using the same piece of equipment for both craft and food, but this is soap for goodness sake! I am more concerned about getting a bit of old broccoli in my soap than having food taste funny. Just wash it well and you will be fine.
Optional - Things you might want to add to your soap to make it look pretty
Glass or plastic beads
Children's novelty pencil rubbers
Small soaps or pieces of commercially made soap
Buff Puff - Those scrubby things made of plastic-y netting.
Small plastic or rubber toys
Glitter
Gold or silver powder
Fake flowers
Any other non-organic, non-ferrous item you wish to embed in your soap. Don't be tempted to use anything that could react with water (e.g. dried flowers) as the soap has a high water content. It might look pretty now, but mould or rust in soap is not a nice idea!
This seems like a lot of stuff to buy, but really you can make do with the minimum to start with and add to your collection as you go along. The more expensive parts are the soap base, the colouring and special soap moulds. Everything else can be bought cheaply for a few pounds or less. If you keep your eyes open and shop around a bit you will find all sorts of things you can use, even if they are meant for something else entirely!
35 comments
May 14, 2012. 1:48 PMbossmansam says:
i remember when i was little my mom would buy me soap with an action figure in the middle for christmas and i had to use the soap to get the action figure i should make those for my nefew
Sep 1, 2011. 6:33 AMsoulpower2 says:
These are just fab. I take it the swirl effects is a similar procedure to making a swiss roll. Can I ask, when you are layering I assume you have to wait until each layer kinda set before putting the next one on.... Cheers
Mar 23, 2011. 9:36 AMjameshatty says:
I used to do this, especially for presents! Then i came across another really good idea on the subject of making soap.
You use two flavours of soap you really like, or the slivers of old soap you don’t want to throw away and use the JoeSoap. It acts as a backbone to form a new re-usable bar of soap with the fragrances you chose on either side.
Here is one for £2.99 on ebay – bit.ly/g3va2S (copy this into address bar)
Jan 16, 2009. 8:56 PMfriendofturtles says:
I bought a book with my melt and pour soaps and as it suggested specific types of organic matter that is what I added. I had no trouble with mold or anything gross but i couldn't tell you why it just doesnt seem to be a problem. I have used honey and oatmeal with a goats milk soap base, patchouli leaf (dried) and patchouli essential oil with goats milk base, and lavender flowers(dried) with lavender essential oil in olive oil base and with goat milk base , and peppermint essential oil ( tried to swirl a glycerine base and an opaque base, didn't look like candy as I hoped but was pretty )This was a fun , easy project. Does anyone know if you can buy an unscented or more natural version of soap base? All I have found have a lot of their own fragrances in them , still blend nice but I was hoping to make it more hippie style. : )
Mar 12, 2011. 7:29 AMmoutngrrl says:
Hi there! You can most definitely find unscented or more natural glycerin soap bases! I just found out recently that if you're looking for a more natural one, you want to look for an SFIC glycerin soap base, these contain no SLS (sodium laureth sulfate). If you are in the US, you could try these websites: http://www.brambleberry.com/Bramble-Berry-Bases-C11.aspx (for 2lb or bulk) or for bulk only soap (20 or 40 lb) http://essentialsbycatalina.com/shop/shopexd.asp?id=879 You could also try http://fromnaturewithlove.com/soap/MandP.asp, but these DO contain SLS. Good luck!
Jul 14, 2009. 4:49 PMhajamaro says:
hi i'd like to ask a question i tried to melt the glycerine soap in the microwave but it didnt turn into liquid.....i dont know why... i used a glycerine bar of soap which i bought from the supermarket......is this the right type or not?!!!! thanks a lot in advance for ur answer
Mar 12, 2011. 7:10 AMmoutngrrl says:
Hi there! A bar of glycerin soap from the grocery store is not quite the right type. You should go to your local craft store and find the candle- and soap-making aisle. They will have what you need. Good luck! :)
Dec 4, 2010. 10:21 AMucanBanerd says:
QUestions...I'm going to be doing met and pour for the first time, does anyone know is it safe to use your pyrex cup again for food, or should you get a separate one for soap making?
Jul 31, 2008. 7:44 PMSoapyHollow says:
Great instructable! And the "mold" soap...in the right scent, is really cool. Like...a dirt and grass scent, and you could call it Graveyard. ;)
May 7, 2010. 8:39 AMbluestockings says:
Soapy Hollow, OMG, I really love your imagination!! Do you have anymore earth friendly scents for soap or bath salts? I can make the soaps but I have trouble combining my soaps to make an earthy smell. Help me out pleasse........ Thanks S.H from Bluestockings
May 7, 2010. 8:26 AMbluestockings says:
Very nice idea and also easy for kids at age 8-14 and above. They love to do the decoration and the design. I was surprised at how Teen Aliens love this so much. We just used small loaf pans and blocked them off with cardboard to make it look like a long loaf when it was only 1 bar. then, block another one off and do the same with a diffirent design. Teen love to to Mystery Loafs, they are creative at this age and love design. You would  be surprised at what little ones, 8 and up can come up with. It is good to plan ahead with kids and do the microwave yourself or with older Teen Aliens. I just call them that because they are so different from the  rest of the world. I love them!  Keep on being creative. bluestockings
Aug 26, 2008. 11:48 AMivonce77 says:
Thank you!
Mar 7, 2010. 7:07 PMb1russell says:
Wow! I finally have found a use for all those IKEA ice cube trays of too-cute shapes!  Stars and hearts and teddy bears, oh my!  Thanks for the great 'structions.
Jan 1, 2010. 2:13 PMsam0203 says:
Thanks so much for the instructions. Me and my friends did this last night and it was a blast!
Dec 15, 2009. 12:43 PMfragile.ecstasy says:
Would it be possible to use vodka or something of the like instead of surgical spirits? I've seen it mentioned in other tutorials, but don't know if it'd be okay here. I'm still pretty new to soap making.
Aug 13, 2009. 7:48 AMDarcy777 says:
LOL Surgical spirits - how adorable. I am sure my way of speaking isn't at all adorable like that.
Jun 29, 2009. 10:52 PMseankreynolds says:
My ex-girlfriend uses sheets of the clear plastic film intended to enclose gift baskets--you just blow on it with a hair dryer and it shrinks to fit. I don't recall her ever having a problem where the soap melted from the hairdryer (I suppose if you left it running on one part of the soap for like 30 seconds it might be an issue...).
Nov 30, 2008. 4:26 AMsolo.card says:
I like this alot! I don't think I've got the time for Christmas gifts now, but maybe other presents?! :)
Jun 28, 2009. 11:24 AMsophmae says:
I usually make mine on x-mas eve because I'm a procrastinator!
Nov 7, 2008. 12:43 PMantonia says:
Thanks for you reply, I will let you know when I try to shrink wrap. Do you know anything about making bath salts?
Nov 5, 2008. 8:01 PMantonia says:
Your soaps are so beautiful! How did you make the green bar of soaps with with gold stripes. I am impressed.I would like to shrink wrap my soap do you think it would work? I would like to make these for christmas, is NOV too early?
Nov 8, 2008. 8:40 PMantonia says:
Do you use those powdered pigments, called. jacuarad?
Nov 8, 2008. 6:51 PMantonia says:
I was wondering do you have an soap recipies you would be willing to share?
Aug 1, 2008. 12:21 PMBadgergirl says:
Great instructable! Now I want to go and make soap!
Jul 13, 2008. 8:28 PMDoctor What says:
After visiting the folklife festival, I've wanted to know how to make my own lavender soap. Thank you!
BTW, the mold soap is really cool! Definately not a flop.
Mar 2, 2008. 4:18 PMalbatronix says:
Here's a suggestion! I found that if I take a crappy coffee grinder (my boyfriend has a super nice one, so I got his drugstore $16 leftover one) and put smallish blocks of soap in it and grind them. It makes the soap melt really nicely!
Dec 23, 2007. 8:59 AMMiss World says:
I love this! :) thank you for the instructable.. I've always wanted to know how this is done! :)
Dec 15, 2007. 7:24 PMBrennn10 says:
Cool stuff! Man, almost 10:30, I really have to get to bed! Nice i-ble!
Dec 15, 2007. 12:18 PMSunbanks says:
I really like the orange slice soap. I used to make soap and put pressed flowers in it and it looked really cool. I need to get some more of that soap stuff...
Dec 15, 2007. 10:47 AMGorillazMiko says:
can i eat the soap? just kidding haha
Dec 15, 2007. 9:44 AMcowscankill says:
this is great. Just what i need :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Babyshoes
