Step 5Finishing up
To de-mould the soap, tip the mould upside down over a suitable surface, and gently flex your mould and push the base. If it is properly set, the soap should pop out quite easily. If not, leave it a while longer or try the freezer trick. A complex pattern in your mould will make it more difficult to remove.
Admire your soap, then wrap it in cling film. You don't need to do this immediately, but certainly within a day or two, as the soap can 'sweat' if left out for too long. If you like, you can make a fancy label for it.
Add Comment
