Memory Coin Keyring
2,848
22
Posted
Introduction: Memory Coin Keyring
Since my brother and his wife have recently had their first child, I thought I'd make them a nice memory gift for it (not that it's the kind of thing that slips your mind really). I've made one for myself and my children before but didn't record the process but this is done in the same way.
Step 1: 1: Required Items
First of all, and fairly self-evidently, you'll need the correct number of coins of the correct year. In this case, 1984, 1986 and 2014. I only discovered after starting to collect the coins (which took about three months) that in the UK we apparently produced very few pennies in 1986 and very few tuppences in 1984 but was eventually able to find matching pennies for all three years.
I bought a cheap keyring and removed the plastic tab. The garden wire will be bent into loops to fasten the coins to this.
I also used a piece of wood with a hole drilled into it to rest the coins in whilst working, to prevent them from being flung across the shed if they slipped.
Step 2: 2. Drilling the Holes
I slotted the coins into the hole and chose the spot to drill through - the top of the queen's forehead in each case. I put a small drop of oil over the spot before using a dremel to drill to reduce friction and heat (although the heat buildup was pretty impressive).
Step 3: 3. Cleaning the Hole
Once I'd drilled the holes through I used a grinder bit (not sure of the exact name, but it resembles a dentist's drill) to smooth the edges and remove any metal snags.
I did this on both sides of the coin, making a smooth lip to the hole.
Step 4: 4. Adding the Loops
I stripped the plastic from the wire and wound it around a piece of metal (changeable screwdriver - rubbish quality but a nice shiny blue look) to form a spring. I then snipped the wire loops with pincers and slid them through the holes.
I put the loops around the keyring and tightened them with pliers carefully. This doubled the loops over due to the length of wire used and helped with the strength of the fastening.
Step 5: 5. Finished
After taking the actual introduction image, I decided to add a connecting loop of chain onto the keyring as the coins didn't look quite right when directly onto it. I made sure whilst fitting that the coins all faced the same way - easy thing to get wrong and it looks much nicer as a matching set.
The other image is of the one I made for myself. The 2p is for me and the two pennies for my children. I had originally wanted to do the same thing for the gift (larger coin for the parent) but was unable to find the correct dates so decided to use matching coins instead.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
3 Comments
You do know this is illegal right? You can't by law deface or damage (on purpose) money. But in saying that nice outcome :)
Given that most tourist places in this country have penny squashing machines, I somehow doubt that it's illegal (or if it is, that anyone cares). There is a law against defacing banknotes but nothing about coins that I was able to find. Don't forget though that in the UK it's still illegal to carry a plank or ladder along a pavement, slide on ice or snow or to be drunk in a pub but they don't seem to enforce those either.
Glad you liked the design btw, thanks. :)
As long as the currency in question is not used to purchase anything. There are places where you can pay to have a penny or quarter squished and imprinted with a new design, and it's legal. And while they're still pennies and quarters, if I attempted to use them to buy something, then it's illegal.
