Memristors in EasyEDA
Published
Introduction: Memristors in EasyEDA
Demonstrating the EasyEDA Memristor using the ngspice Memristor XSPICE element.
https://easyeda.com/andyfierman/Memristors_in_Easy...
The memristor is a two-terminal resistor with memory, whose resistancedepends on the time integral of the voltage across its terminals. rmin andrmax provide the lower and upper limits of the resistance, rinit is itsstarting value (no voltage applied so far).
The voltage has to be above a threshold vt to become effective in changingthe resistance.
alpha and beta are two model parameters.
The memristor code model is derived from a SPICE subcircuit published in:
Y. V. Pershin, M. Di Ventra: "SPICE model of memristive devices with threshold",arXiv:1204.2600v1 [physics.comp-ph] 12 Apr 2012,http://arxiv.org/pdf/1204.2600.pdf
See also:
Dalibor Biolek, Member, IEEE, Massimiliano Di Ventra and Yuriy V. Pershin, Senior Member, IEEE:"Reliable SPICE Simulations of Memristors,Memcapacitors and Meminductors"arXiv:1307.2717v1 [physics.comp-ph] 10 Jul 2013http://arxiv.org/pdf/1307.2717v1.pdf
For more information about the the ngspice Memristor XSPICE model, please see:
http://ngspice.sourceforge.net/docs/ngspice-manual... For information about Memristors, please see: http://ngspice.sourceforge.net/docs/ngspice-manual...
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    Thanks for sharing!
