Now you can make a matching set.
http://www.instructables.com/id/Sweetheart-Nickel-RingPendant/
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
http://www.usmint.gov/consumer/?action=FAQ
Can I make jewelry from U.S. coins?
Yes, but your business should be careful not to imply any endorsement by or association with the United States Mint in its advertising and marketing materials
Can I melt, drill holes through, or mutilate U.S. coins?
Maybe. It is a violation of 18 U.S.C. § 331 to alter a U.S. or foreign coin with the intent to defraud. The United States Mint cannot issue interpretations of criminal statutes such as this, which fall within the jurisdiction of the U.S. Department of Justice. Furthermore, 31 C.F.R. Part 82 states that no person shall export, melt or treat any 5-cent coin or one-cent coin of the United States. HOWEVER, there are a few exceptions such as for novelty, amusement, educational, jewelry and similar purposes. Your business should consult with an attorney to ensure it does not run afoul of these laws before melting or mutilating U.S. coins.
Silver is soft and easier to work with, also doesn't leave marks on the skin.
http://www.instructables.com/id/Five-Cent-Hoop-Earrings/
Great to see it can be done "by hand" as it were.
By machine, "washers" are stamped out of strips of metal. They are then pressed in the middle (coning) with a hydraulic press, creating a cone, then they are pressed through a polished hole (converting) which turns the washer into a short round tube which is called a slug.
The slug is then put into a press roller which rolls the ring with a steel mandrel in the middle against a nylon press. This expands the ring ready for the CNC lathe.
The only thing I'd warn against with using coins as rings is the high Nickel content of the coins (search "cupronickel") , but for the majority of people, this is a great thing to do.
Its probably safe to say that most of the users here are aware of what hazards they may encounter when performing an 'ible, and that those with a nickel allergy would realize the risks involved with utilizing a coin as a material that is commonly referred to as a "nickel". My five cents.
And if you have any project ideas for me let me know. I'll gladly make the i'ble.
