Introduction: Mens Latex Y-front Brief
The mens latex y-front brief is typically worn as underwear and made from latex sheeting or 4-way stretch vinyl. It has a close fit the same way that traditional underwear or swimwear would fit.
Step 1: Gather Your Materials
- Mens y-front brief pattern - custom to your measurements
- Latex sheeting in 2 colors
- Latex glue
- Gloves
- Seam roller
- Rotary Cutter
- Cutting Mat
- Latex shine (optional)
- Scrap paper (to keep glue off your working surface)
Step 2: Cut Out Pattern Pieces
Place your pattern on top of your latex sheeting, and cut out the various pattern pieces using a rotary cutter on top of a cutting mat.
** When you cut out the trim pieces, add an extra 1/2 inch to the ends - if it's too long you can always cut away the excess, but if it's too short, you'll have to cut a new piece. **
Step 3: Glue Front Trim to Front Section
- Place the front section on your working surface and then layout your front trim pieces on top of it to ensure that everything comes together properly.
- Mark the location of the trim pieces on the front section.
- Brush on glue to the front section where the trim will go. Make sure that the glue is slightly wider than the trim.
- Starting at one end, adhere the trim to the glue. Working slowly down, and making micro-adjustments as you go.
- Try not to stretch the trim as you adhere it to the rear section.
- Press the trim to the front section using your seam roller.
- Use as much pressure as you can.
- Roll at a 45 degree angle to the trim.
Step 4: Glue Trim to Rear Section
- Brush on glue to the rear section where the trim will be placed. Ensure that the glue is slightly wider than the trim.
- Adhere the trim to the rear, working from one end and progressing slowly - making micro-adjustments as necessary.
- Try not to stretch the trim as you glue it.
- Press the trim to the rear section using your seam roller.
Step 5: Glue Front to Rear at Side Seams
- Put glue on the left side front and left side rear. Allow the glue to get tacky (wait a minute or two).
- Use a 1/4 inch seam width.
- Place the rear directly on top of the front, and work your way down the seam, adhering the front to the rear.
- If the front and rear do not match perfectly, either start over and try again (if more than 1/2 inch off), or carefully trim away the excess using your rotary cutter.
- Press the seam with your seam roller.
- Roll at a 45 degree angle to the seam.
Step 6: Glue the Crotch Seam
- Glue the front to the rear at the crotch.
- Ensure that front and rear line up perfectly. You can stretch the material slightly if necessary as you are gluing it.
- Press the seam together using your seam roller.
Step 7: Glue Waistband (optional)
- Apply glue slightly wider than the width of your waistband, to 1/3 the length of the waist.
- Start at the rear, overlapping the middle of the rear by 1/4 inch.
- Work your way across 1/3 of the waistband. When you get to the end of the glue, apply adhesive to another 1/3 of the waistband. Work your way slowly down that section, and then repeat 1 more time.
- Overlap the waistband by 1/4 inch over the waistband at the middle rear.
- Press the waistband to the brief using your seam roller.
- Roll at a 45 degree angle to the waistband.
Step 8: Wait 24 Hours, Then Celebrate!
- Give your seams 24 hours to cure before putting any stress on them.
- Celebrate - you just made a pair of custom latex briefs!
