Mentos and Diet Coke Rocket
 by Mjeden2006
Launch a 2 liter over your house, No promises!
Also please use ccaution when performing this experiment there is always a possibility of injury or damage to property, please launch in wide open area with pleanty of space in all directions and never attempt to launch in the direction of another person as flying 2 liters can hurt!
Step 1: Purchasing!
Go to you local gas station or grocery store and purchase as many materials desired, for one launch you need only:
1- 2 Liter Bottle of Diet or Diet Caffeine Free Coke(Pepsi does not work as well)
2- Mentos(Mint not fruit flavored)
georion says: Nov 23, 2011. 8:36 PM
anybody get hurt---seems dangerous the way You do it
LoveOutLoud says: Jan 14, 2008. 7:07 PM
Is this a chemical reaction or a physical ?
princemyheart in reply to LoveOutLoudFeb 5, 2008. 6:47 PM
Both!
sciencegeek12 in reply to princemyheartApr 28, 2008. 10:02 PM
actually its a physical reaction only because nothing new is being created
PKTraceur in reply to sciencegeek12Oct 7, 2008. 7:15 AM
if this is "just" a physical reaction, how come the bottle is propelled up?!?!
princemyheart in reply to PKTraceurOct 7, 2008. 3:08 PM
The bottle is propelled up.... mate.... that IS a physical reaction! Can't believe that there is NO chemical reaction happening somewhere in the bottle though. Cheers Royce www.funshow.com.au
arf200 in reply to princemyheartMar 19, 2010. 7:25 PM
It is all physical the mentos it creating an area for the carbonation buble to form fast enough that it builds presure enough to lunch the bottle
mattccc says: Sep 23, 2009. 2:31 PM
sweet!!!!!!!!!!!
Mattrox says: Feb 13, 2009. 2:57 PM
weight is not a force. Gravity is the force that acts on weight
34will in reply to MattroxJun 6, 2009. 2:39 AM
No, weight is a force. Gravity is a field that causes weight.
Buck Futter in reply to 34willJul 27, 2009. 1:33 PM
Neither is a force, according to Einstein "Gravity is a warpage of space and time". Weight is just the increased or decreased 'apparent mass' of an object. (Weight = Mass * Gravity). On Earth, gravity = 1, so mass and weight are equal. =D
eshad says: Jun 21, 2009. 6:29 PM
somebody!!! can u help me?? i just want 2 know what is the used of this reaction in our life?? plizz help me...
matoro_toa in reply to eshadJul 22, 2009. 10:32 AM
great fun and a big mess
chibiwind says: Jan 13, 2009. 11:55 PM
The bottle will never reach terminal velocity because it isn't falling like 10kms of a cliff
bylerfamily says: Dec 20, 2008. 11:33 AM
This didn't work!!!!!!I used a water bottle.
Owenmon says: Oct 29, 2008. 10:22 AM
do it in a baseball field and as soon as you throw it run into the dugout
Yerboogieman says: Oct 15, 2008. 4:40 PM
try to drink it while its spraying like weezer did.
Cameronk says: Jan 16, 2008. 5:25 PM
good but sometimes putting the whole thing in makes it fizz a lot more =P what i do is:
Pull the paper off of wrapper.
Open up one side of the foil.
Quickly put the mentos in and screw on cap.
Shake.
Then throw as needed.
Cameronk in reply to CameronkJan 16, 2008. 5:27 PM
oh yeah and forgot ... don't taste the mentos or the diet coke after the launching... tastes horrible lol... diet coke is flat because it fizzed up.. and the mentos taste like diet coke...
taegin in reply to CameronkOct 15, 2008. 3:36 PM
not to mention, the mentos turn ROCK HARD...i blasted them and some landed on me so i ate one...owww
bleedingsoul says: Sep 7, 2008. 11:19 PM
if the bottle could it would sing Cause i'm tnt i'm dynamite i'm tnt and i'll win without a fight watch me explode
popbottle says: Aug 23, 2008. 6:43 PM
dude u can get more thrust if u take 6 mentos together with tape then tape that to the cap believe me u get ALOT more thrust like double even triple the height u wrote good luck -popbottle
zach12 says: Jul 2, 2008. 7:45 AM
will sugarfree mentos work?
Bartboy in reply to zach12Aug 5, 2008. 5:20 PM
no
hacker22 says: May 7, 2008. 4:44 PM
Ok first of all, terminal velocity is the maximum speed an object can FALL, and is the average between the force of wind and the pull of gravity. How can and object with propellent going upwards, reach terminal velocity? And also a bottle can go much higher, you must have had horrible luck.
memzie says: Feb 15, 2008. 10:53 AM
it work nd it flew
Jack Daniels says: Sep 25, 2006. 6:42 PM
done this one befor but it is cheeper to just use same bottle water and dry ice
oakers2 in reply to Jack DanielsNov 5, 2006. 12:22 PM
Were can you get the dry ice?
Mjeden2006 (author) in reply to oakers2Nov 5, 2006. 3:24 PM
Any local grocery store will have it but you need to be at least 18 to buy it!
armageddon in reply to Mjeden2006Nov 8, 2006. 7:23 PM
grocery store? now ive heard everything. i thought you had to buy it at a special place?
Cameronk in reply to armageddonJan 16, 2008. 5:28 PM
safeway sells it these days..
Jack Daniels in reply to CameronkJan 16, 2008. 6:14 PM
walmart sells it as well
TreizeEnder in reply to armageddonDec 19, 2006. 8:26 PM
I buy dry ice for a little over a dollar a pound at SafeWay (local grocery store here). I use it for a tornado machine; great for showing the air convections as carbon dioxide is a white vapor. Just ask the clerk to get it next time you go. They keep it locked for good reason.
Mjeden2006 (author) in reply to Jack DanielsOct 2, 2006. 11:11 PM
But the effect varies with dry ice and a 2 liter only costs a buck and the mentos even less
killa monk4 says: Dec 23, 2007. 11:31 PM
there are tons of movies of this on u-tube take a look
joshc0311 says: Sep 19, 2007. 1:55 PM
i like this but except when i do it i shove the whole package or 2 in and screw the cap on real quick and then shake. it works really well
sciencefreak99 says: Jul 10, 2007. 5:31 PM
mint not flavoured because the flavoured ones are 'laminated' if you know what i mean, theyre glossy, and the surface area is greatly reduced so it has no reaction
armageddon says: Nov 8, 2006. 7:31 PM
actually i think your method would not work. the chemicals play a small part in the reaction. the most important part is the outside of the mentos. there are tiny little craters on the outside of the mentos where the bubbles can form and rise up when they are heavy enough. its is important to put them in whole cause i dont think it would be possible at all to launch it over a building chewed up.
sciencefreak99 in reply to armageddonJul 10, 2007. 5:28 PM
k, thats not the only thing, caffine, i think Potassium Benzoate, Phosphoric Acid, and also Aspartame. they all contribute a bit to the reaction, and also the ingredients in the mentos. using non caffinated isnt practicle because it will lower your 'power'. i wonder if making a checker board desing on a mento work work well, seeing that that would create more surface area.
Mjeden2006 (author) in reply to armageddonNov 8, 2006. 11:01 PM
Yes it does work as I mentioned before I've done it, with comparable results! Only one, not both of the mentos is chewed up, this provides enough of the chemicals for the reaction and pleanty of places for the CO2 to form bubbles. Good information though, you must watch MythBusters.
Gamer917 in reply to Mjeden2006Aug 9, 2009. 12:19 AM
so do i and i watched Adam do something like this on the show. It was also funny when he put a bottle of coke on the lathe and it exploded
Yerboogieman says: Jul 7, 2007. 2:35 AM
it went FAST in the video
toogood says: May 2, 2007. 10:29 AM
my brain hurts!!
armageddon says: Nov 8, 2006. 7:25 PM
(removed by author or community request)
Mjeden2006 (author) in reply to armageddonNov 8, 2006. 11:02 PM
okay this comment is just dumb!
BobertXXL says: Nov 7, 2006. 10:09 AM
You can make a PRETTY POWERFULL gun out of this.
BobertXXL says: Nov 7, 2006. 10:08 AM
opolopolis! says: Nov 5, 2006. 2:59 PM
Who in the hell would put the word kum in the name of their gas station?
Monkeybo1 says: Oct 3, 2006. 6:01 PM
Actually, what you do is: 1) Take paper wrapper off mentos (leave foil on). 2) Drop whole mentos package (without paper wrapper) into 2L of diet coke. 3) Screw cap on and shake. 4) Unscrew cap slowly until you hear "hissing" sound. 5) Throw onto the ground sideways with two hands. Really the cap is not breaking, but it is unscrewing and letting the pressure out. I've never tried your consept but it might work.
Mjeden2006 (author) in reply to Monkeybo1Oct 3, 2006. 7:43 PM
with this method you need to actually break the cap off this way it releases all the pressure at once instead of little by little!
Monkeybo1 in reply to Mjeden2006Oct 10, 2006. 5:43 PM
No, when the bottle hits the ground the cap completly unscrews and lets out all of the pressure.
theRIAA says: Sep 25, 2006. 10:32 PM
you have never done this, neither have I, but i know that will not work. if i was doing to do this i would use a whole roll of mentos. all you have to do is NOT take the packaging off, just smush it up a little so it will fit, put the cap on quick, and shacking the bottle will loosen the packeging. THEN you have to loosen the top so it just starts to leak, THEN you throw it down
Mjeden2006 (author) in reply to theRIAAOct 2, 2006. 11:11 PM
Actually I have done this one before and it does work, as long as you throw it right
stupidkid2000 says: Sep 30, 2006. 3:35 PM
I just got a really nasty idea. Go to the grocery store with some tape and some mentos in your pocket. Find a secluded isle that contains soda bottles. Open one of them, tape a mento to the inside of the cap, screw back on, shake it, and leave quickly. Imagine how mad it will make whoever byes it.
stupidkid2000 says: Sep 28, 2006. 9:04 PM
For more information on this trick, visit
http://www.mentosandcoketrick.com/index.php?option=com_content&task=view&id=15&Itemid=29
They do some really crazy things!!!
Grimling says: Sep 26, 2006. 9:51 AM
Not work ? This is the oldest trick ever ! And you don't need menthos , you can do it with coins as well... , don't forget to put some glasses on or something , if coke get into your eye's , that ain't funny
FrenchCrawler says: Sep 25, 2006. 6:44 PM
Just linking your instructable to the similiar ones:
1. http://www.instructables.com/id/EMACBJDJUVEP286YSH/
2. http://www.instructables.com/id/EHNPYDFP66EP287NSR/
You could say this is a "mod" of these since you're using the bottle as a rocket instead of a fountain.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
