Introduction: Mentos+Cola Spray Bottle.
You probably know what happens if you mix Mentos and Cola. I will show you how to make the burst more controllable so you can spray a person+ I will show you how to make a Mentos+Cola remote grande.
MATERIALS:
FOR THE SPRAYER:
1 2 litter bottle of Cola
1 pack of Mentos
pvc pipe
pvc valve
FOR THE GRANDE:
8oz water bottle filled with Cola
1 pack of Mentos
small wooden peg
long string
drill.
tape
Step 1: Making the Sprayer
To make the sprayer use a piece of pvc pipe to make the nozzle. You can probably find special attachments at a hardware store. Make sure that it is airtight by putting a nice layer of hot glue on the seams.
TO USE IT
Plug the end of the pvc pipe with a cork with a string attached.
Put Mentos inside the bottle.
Aim
To fire pull the string.
Step 2: Making the Remote Grenade
To make the remote granade find a place to set it of, like a doorway or driveway.
Then find the nearest hiding spot.
To make it drill a hole in the peg and tie the string around it.
Drill a hole in the cap that is the same diameter as the peg.
Insert the peg in the cap.
Fill the bottle with Cola+Mentos
Tape the bottle to some thing, but make sure the peg is facing the target.
Makesure the string reaches from the bottle to the hiding place.
Hide in the hiding place with one end of the string.
When target walks by pull the string hard.
IM NOT RESPONSIBLE FOR THE RESULTS
COMMENT
About This Instructable
111views
0favorites
License:
More by weasel999:HOW TO MAKE A REPLICA OF THE FAMOUS ALTOIDS TIN. (AND RECYCLE AT THE SAME TIME)How to make a little city for a movie.How to make a pocket sized ninja sword. (ninja pocketknife).
Add instructable to:
