3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mercury Joe: Semi-scale flying GI Joe Redstone Rocket
This project was inspired 40 years ago when I got a GI Joe Mercury Capsule for my birthday. I always imagined it flying (even orbiting) and it kept me out of my parent's hair for days on end. Fast-forward to the mid 90s when the GI Joe Capsules are re-issued by Toys-R-Us -- naturally I picked up one (well 3). After the popularity and success of the Gumby flights I simply had to look to the shelf above my workstation to be inspired for my next big project. When I found a tube that was 9.25" (the exact diameter of the Capsule base), this project was set into motion.
A LOT of this project was engineered on the fly and by no means reflects the best way to approach the tasks described.  It's just how I did it and you're welcome to make changes any way that suit your engineering skills.
I offer this in hope  that this 'instructable' will inspire others to build and fly similar projects.
Step 1Preamble
Preamble
To send a full GI Joe capsule aloft (with Astronaut), have the capsule free-fall and deploy its recovery system safely. The entire flight will be recorded by three (to 5) different on-board video systems.
This ISN'T a scale project; the "Mercury Booster" is a little thicker than the real thing. The "Mercury" capsule is built from the GI Joe unit, is under scale as well.
The big challenge of this project is to perfect a system that allows the capsule to free-fall to a safe altitude before deploying its parachutes. Technically this is no more than a dual deployment flight, but the added complication of extracting the tower so the capsule can free-fall is anything but simple.
At apogee the capsule (with tower) will decouple from the booster.
The capsule has a deployment bag attached to the heat shield which will pull out the pilot chute for the booster.
The decoupling activates an ejection charge timer inside the tower, allowing for the capsule and tower to drift away from the booster which will be unfurling its main chute.
Once the tower charge has fired and its chute has inflated, the weight of the capsule causes it to fall free off the tower base.
The capsule free-falls to about 1500' before deploying a pilot and main chute combination.
With all going to plan, video of the flight is captured from the booster, looking up and down,  the Tower, looking down and the capsule, both interior and an additional view down.
42 comments
1-40 of 42next »
Apr 12, 2012. 12:30 PMthe_burrito_master says:
Toilet paper tubes, it ain't rocket science fellas ;)
Mar 9, 2012. 6:20 PMAron313 says:
This should of won 1st!
Oct 1, 2011. 6:05 PMrimar2000 says:
Great work!! Congratulations.
Sep 28, 2011. 7:33 PMitsjustdoc says:
So. Gorram.Cool.
Aug 15, 2011. 3:30 PMSurfRW says:
This is amazing :O
Aug 12, 2011. 11:01 AMIwantbigboom says:
wasnt your rocket in ldrs (large dangerous rocket ships) or was that somebody elses mercury joe
Aug 12, 2011. 12:09 PMIwantbigboom says:
no I mean the one in 2009
Jul 15, 2011. 7:21 PMprofpat says:
nice project!
Jul 14, 2011. 5:33 PMATTILAtheHUNgry says:
Awesome!
Jul 14, 2011. 7:17 AMshobley says:
This is amazing stuff.. well done.
Can I be the first to say "SPAAAAAAAAAAAAAACE!!!!"
[Portal 2] :-)
Jul 14, 2011. 12:46 PMvenecha says:
This is awesome! Thank you for taking the time to put this together!
Taking Shobley's idea a bit further though...it would be fun to mix the personality core screeching 'SPAAAAAAACE' to go off at time of launch *grin*. I might have to look into doing something like this and adding it in.
Jul 10, 2011. 11:00 AMseamster says:
This is really awesome! I love seeing things like this posted here. I'm still just an estes rocketeer, but this makes me want to join the big leagues. Wow!
Jul 14, 2011. 12:13 PMlockpick says:
Is there an ave limit on high powered rocketry?
Great rocket and ible by the way... I have always liked scaled rockets.
Jul 14, 2011. 1:14 PMDead-Portalist says:
I remember when I made a rocket from scratch using a toilet paper tube, cardboard, a straw, and a plastic bag. Best rocket I've ever flown.
Jul 14, 2011. 10:07 AMaskjerry says:
Nicely done!
I really appreciate the detail you put into that... shows off the sport very well... and the video was outstanding!
Jerry
TRA 5787
Jul 14, 2011. 7:41 AM66tbird says:
Very nice build. Sure bring back memories.
Jul 12, 2011. 3:19 PMMatrix-technician says:
Wow! This is an amazing build, I have been involed in model rocketry since I could pick up a bottle of glue and a xacto knife but i've stuck closely to scale model engeneering. I seem to have trouble when i build out of scale.
Jul 11, 2011. 7:02 AMtinker234 says:
wow hey where can i find a mercuy joe set
Jul 11, 2011. 10:32 AMtinker234 says:
ok i looked i found aone but i like yours better
Jul 11, 2011. 7:28 AMJCoffey says:
Beautifully built! What motor are you tossing her up with? Have you braved a cluster yet?
Jul 10, 2011. 6:31 PMKaptain Kool says:
Great detail on the rocket! I love it!
Jul 10, 2011. 2:21 PMkelseymh says:
This is an amazing Instructable, and I'm quite impressed at the level of detail you provide. Thank you for putting it together for the rest of the community!
Jul 10, 2011. 5:58 AMDELETED_hkopfs9a says:
(removed by author or community request)
Jul 10, 2011. 8:01 AMKiteman says:
See where it says "flag" in the bottom corner?
Jul 10, 2011. 2:18 PMkelseymh says:
On a side note, the "[delete]" only appears for your own comments, or for all comments on your Orangeboard.
You're quite right (below) that the current UI makes it really non-obvious that "flag" is separate from "Feature".
Jul 10, 2011. 10:18 AMKiteman says:
It's gone because the Admins have been chasing down a particular spambot.
You should be able to see a flag button on most comments (see picture) - if you can't, that may be a Chrome issue. Lithium Rain says that the non-google version ("Chromium") is better.
Jul 9, 2011. 9:41 PMmikeasaurus says:
This is amazing, great work documenting and experimenting!
Would like to know more on your payload recovery methods? (tracking, logging, line-of-sight, other?)
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:JamieClay
I'm just this guy, you know.
