Mermaid Knitted Tail
532
4
7
Posted in CraftKnitting-and-crocheting
Introduction: Mermaid Knitted Tail
A Mermaid is a legendary aquatic creature that nowadays has become trending topic, and so this incredibly comfy kitted mermaid tale.
For this winter I will show you the easiest way to knit your own mermaid tail, so pick up your favorite colors, and become a beautiful mermaid.
Step 1: Step 1: Materials
What you´ll need:
A measuring tape
A Knitting hook size 8mm
Yarn, lots of it
A needle for yarn
Step 2: Step 2: Measures
First you need to take your measures, you want
this tale to be especially for you, so grab your measuring tape.
First you need to measure your chest, then the length from your chest to your hips, then the size of your hips, including your butt, and the length from your hips to the tip of your toe, and the size of your ankles together.
Choose the biggest size, it can be the chest size or the hips, and that will be our starting point.
Step 3: Step 3: Chains
Make a chain to turn and on each stich make a have double crochet.
Knit as many rows as you need to get to 20cm length.
Step 4: Step 4: Start of the Body
On the 21cm row you will do a slip stich to join both ends, and knit as many rounds as you need to get to the measure of your torso.
Remember on each round you need to do a slip stich to keep the cocoon shape.
NOTE: You need to count each stich, and make sure you have the same amount of stiches as in the beginning.
Step 5: Step 5:
When you get to your torso length, find the middle point of your cocoon, and on each side make a half double crochet decrease, so you will have 2 stitches less than when you started.
Knit 3 rows, and on row 4 make a half double crochet decrease on each side of the cocoon, that till you get to your hip to toe length.
Step 6: Step 6: Close the Cocoon
To close the cocoon you will use your needle and stitch both sides.
Step 7: Step 7: Mermaid Fin
Now it´s time to make the mermaid fin.
For this you will start with 30 stitches, make a chain to turn, and make one double crochet decrease, then on each stitch make a double crochet, by the end of this row you will have 29 stitches.
On the next row you will make the double crochet decrease on the last stitch. (By the end of this row you will have 28 stiches).
Repeat this till you get to 20 stitches, which will be the center of the fin.
NOTE: you´ll have to work all the rows on BLO (the back loop only).
On the next row, make a chain to turn, and on
the firs stitch make a double crochet increase. (By the end of this row you´ll have 21 stiches).
On the next row you will make the double crochet increase in the final stitch. (By the end of this row you´ll have 22 stiches).
Repeat this till you get to 30 stitches.
When you do the knot on last stitch make sure to leave a large piece of yarn.
Step 8: Step 8: Get the Fin As Wide As the Bottom of the Cocoon
The top of the fin now will be gathered to match up the bottom of the cocoon.
For this you will insert the needle on the ending yarn of the fin, and sew only the top of the fin, then pull the yarn to gather the fin till it gets as wide as the bottom of the cocoon, and make a knot.
Step 9: Step 9: Sew the Fin With the Cocoon
Stitch the top of the fin with the bottom of the cocoon, and you will have your perfect mermaid tale.
Thanks for watching thins instructable.
    • Flowers Challenge
      Flowers Challenge
    • Spotless Contest
      Spotless Contest
    7 Comments
    Looks great! This is crochet, though, not knit. Do you have the knitting instructions? I'd love to make it!
    This is a really cool idea! Are there instructions for knitting instead of crochet?
    No sorry, only crochet, but it is simple, you should try
    Really nice work - but its described as "knitted". I see only crochet here. Am I missing something?
    No it is crochet only, sorry I got a mistake with the words
    I love how full you made the fluke. Looks beautiful!!!
