So far, I have used this bender to make circles out of 1x1/16 aluminum for some of my hobby robots, to bend some 1x1/8 inch aluminum into a perfect circle for a US First Robotics high school team I mentor (Go Team 1631), and to bend two 5 inch wide 1/8 inch steel sheets 9 feet long for a fire pit I am making (but that’s another instructable).
This instructable will have you cutting metal and braising. Don’t forget all the safety rules involved with each of these activities. If you are new to any of the tasks below, I recommend looking up safety tips on the internet before trying something new. As you will see in step 10 “Next Time” I made a few errors on this one, but I finished with all my fingers and toes intact. That’s a good thing.
This is my first of hopefully many instructables, so if something doesn’t make sense, just ask, and I’ll try to explain it better.
Remove these ads by
Signing UpStep 1: Parts and Tools
Qty Item
3 Printer rollers removed from old printers
2 4 ft pieces of 1x1 Angle Iron
1 3 ft piece of ¼ in C-Channel
1 3 ft piece of 2 x ¼ inch flat metal
1 Conduit pipe holder
1 ¾ x 9 inch bolt and nut
Scrap rebar or other metal
Finishing nails
Tools
Tape Measure
Level
Metal saw
Welder
Magnetic 90 deg holder
3lb Sledge Hammer
Chisel
Visit Our Store »
Go Pro Today »
1. Twist the top screw so the flat metal you want to bend fits between the rollers.
2. Give the top screw another 1/4 to 1/2 turn
3. Use the handle to roll the piece of flat metal passed the middle roller. Make sure you do not roll the metal off the machine.
4. Repeat steps 2 and 3 twisting the top screw and rolling the metal back and forth.
As you do those steps, the metal slowley bends into a circle. It takes alot of passes back and forth to make a full circle, but it works great.
Anyway, good job, and good luck in the challenge!
printer roller came from a dot matrix printer?
Thanks
I've always thought I would make a roller, but havent yet.
