3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Metal USB - Flash drive case mod
A case mod for a Flash Drive made with a heatsink.
Step 1Find Parts
You will need:
Flash Drive I used a PNY attache (256 - yeah, it that old (2yrs))
A metal case I used a heatsink form a dimmer, but anything should work (golo e115041 sc237)
Keychain Flashdrive -keys= external hard drive I'd reccomend something, but it's not critical
Nails I used a strip of brads for an air nailer, but anything will work
Glue Super glue (loctite gel) and plastic cement (testors -for models)
Tools:
Drill For attaching keychain and a hole for the light (I was lucky and didn't need a hole for the light)
Pliers
File Sharp corners, etc
Hacksaw blade you can use a file instead
Leaterman Do I even need a reason?! /Just cuz
A Brain Don't cut yourself, ruin your computer, etc IF YOU DO IT"S NOT MY FAULT
43 comments
1-40 of 43next »
Mar 5, 2011. 12:37 PMfreakyqwerty says:
Did you now that this 'ible has been linked to from here?
May 9, 2009. 1:38 PMthoraxe says:
hey where do you get that ring from? i only have one of those
May 23, 2010. 3:07 PMGrey_Wolfe says:
You can get ring clips like this from quarter toy machines, or crafts stores like Micheal's is the US.
Apr 22, 2009. 1:28 PMGTAman2175 says:
Wasn't there an instructable on this already?
Apr 22, 2009. 8:29 AMbrandonmiller21 says:
dimmer switch...I think he is talking about one of those "slider switches" for your house. They dim the lights when you slid it up and down...but I'm probably wrong.
Mar 26, 2009. 11:28 AMfatman999 says:
your soldering SK1Lz are l33t and so is this flash drive
Mar 22, 2009. 5:50 PMsilent_thunder says:
what is a dimmer switch
Feb 9, 2009. 10:40 PMGuardian_Rayovac says:
That is a pretty sweet idea! Where was this heatsink form? that's the only part i was confused from.
Sep 28, 2008. 12:43 PMsanta844 says:
where did you get the heatsink from?
Jun 1, 2008. 4:05 PMGorillazMiko says:
I like this Instructable. And your SOLDERING SKILZ. +5/5 stars.
May 31, 2008. 1:56 PMRadioactive_Legos says:
it might be more shock-proof if you seal it in silicone. Also, could you drill a hole in the heat sink for the little flashy LED on the drive? I like this a lot! If I pull out the money to get myself another flash drive to hack up, I'll definitley do this!
May 2, 2008. 7:19 AMTransquesta says:
I like this one a lot. It has a kind of 60's-ish spy movie look. I can almost hear the theme from Mission Impossible. :-)
Mar 29, 2008. 12:09 AMmaxtop says:
usbflashdriveswow.it is cool.i like the light and metail usb flash drives.
Feb 14, 2008. 2:50 PMFreshPineSent says:
very nice!
Feb 9, 2008. 5:28 AMcotton says:
ok but when you do can you make my last comment if you do it into a instructable
Feb 8, 2008. 1:06 PMcotton says:
you should do it with a 16 gb compact flash card and adapter and then add a usb jack to the adapter if it dosent have one and add the metlcase so it is sort of a square case ok
Feb 5, 2008. 4:25 PMultrauber says:
wow, you've got a shnazzy computer. I like all the lights
Jan 28, 2008. 4:54 PMalvincredible says:
clean. alvincredible<3 this instructable
Nov 12, 2007. 4:10 PMwiangube says:
Is it possible to 'transform' a normal USB flash drive in this heatsink?
I bought the SanDisk 256MB Cruzer Freedom in here:
http://www.compuplus.com/ps-products-comboid-417~.html
but would like to know if I can make it safer.
Oct 23, 2007. 5:28 PMRob2_0 says:
this is extremely convinient for me my 4 gig PNY just broke ( apparent ly most rectangular drive tend to break like that) any one notice how the PCB is glued like at an angle from the usb plug. very good stuff though will do tonight thnks
Oct 20, 2007. 2:39 PMSirdizarm says:
Nice! I´ll do one myself :D
Sep 19, 2007. 11:27 AMSimoMies says:
Very nice indeed! Damnit, mine kingstons 2gb flash drive casing got broken and I made a new one from RS-232 connector, but I forgot to take any pics! And I epoxied it into one piece. Damnit.
Sep 16, 2007. 3:24 PMmarc92 says:
i think that instructables should have a flash drive contest since there is so many of them
Sep 16, 2007. 9:26 AMBrennn10 says:
I like this! I have a broken flash drive case, so I need every idea to make a sweeter one! This one is on my list.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
93
Author:LinuxH4x0r
