loading
Step 6: Final layers of concrete
I have read two conflicting statements about adding layers to concrete: that you should do it before the layers underneath have fully set, and that you should do it after. I'm not sure which is true, but I can say that I did it before it was fully set, but ater it had hardened considerably.
The next layer should be smooth concrete. After a fair bit of research, I came up with this recipe: 1 part portland cement to 1 part silica flour (by weight). Mix them thoroughly dry (don't forget to wear a mask!), and then add water as before, just so that the cement is workable.
Again apply a layer of this cement. You can sand it down to get a very smooth finish, as you can see in the photos.
You'll need to cover this/keep it moist as well, so that it properly cures without cracking.
<p>Thanks for this great idea of metal + foam + concrete! </p>
This was very helpful, especially the idea and technique of using foam as free form under structure for the cement. Thanks!
OK, I really wanna try cement sculpture, of course I would buy just the cement without aggregate, and some playsand, using the playsand as aggregate, and then see what happens, although the result would be a really malleable cement mix, which would be really good for working with, as it would be almost like sand sculpture, but it would be permanent.
I love this! It has a very Seussian feel to it, and I'm held in tension over what the lenses might be focused on. Also I've never seen this technique before. Thanks for sharing!
thats a very interesting technique! The glass looks to crooked to be shelves, does it do anything like focus the light or anything special? really a cool looking piece
About This Instructable
36,141views
46favorites
License:
More by ecordell:Cheap, classy, frameless frame for any poster/photo/picture Metal and Concrete Sculpture
Add instructable to:
