Remove these ads by
Signing UpStep 1My new lathe and mill
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
"If you look at the main picture you will see a drill chuck . The sleeved shaft goes on the drill chuck shaft and slides in the bored shaft for when your using a tap in the little chuck . If that makes sense if not i will try and explain it again"
I´m learnin english!!!!
thanks a lot, good job!!!
mauro
I personally don't like them, they seem to be quite inaccurate, but that might just be years of abuse! The best precision I can get seems to be about 0.2mm.
Pro tip: When knurling, start the knurls by hand, by barring the lathe with your chuck key. Once there are some marks from the knurls, the knurls will lock step, and you can turn on the spindle.
Run the process VERY very wet - otherwise the chips clog your nice new knurls.
An ultrasonic cleaner REALLY brings the details out of knurled work.
Steve
