Step 1: My new lathe and mill
Step 3: Turning the main body of the die Jig
Picture # 2 shows drilling the body all the way thru with a 1/2 inch drill .I then bored the end to 13/16 x3/8 deep for the die to be inserted.
Step 4: Knurling
Step 5: Finished main body
2nd , 3rd and 4th picture shows the finished die assembly.
Step 7: 3 handles and knobs
#2 Shows the knobs being polished
#3 and #4 show the finished die jig
video #1 shows the die jig in use chasing threads on the lathe
video #2 shows a ball turner i made making the knobs for the die jig
Visit Our Store »
Go Pro Today »
"If you look at the main picture you will see a drill chuck . The sleeved shaft goes on the drill chuck shaft and slides in the bored shaft for when your using a tap in the little chuck . If that makes sense if not i will try and explain it again"
I´m learnin english!!!!
thanks a lot, good job!!!
mauro
I personally don't like them, they seem to be quite inaccurate, but that might just be years of abuse! The best precision I can get seems to be about 0.2mm.
Pro tip: When knurling, start the knurls by hand, by barring the lathe with your chuck key. Once there are some marks from the knurls, the knurls will lock step, and you can turn on the spindle.
Run the process VERY very wet - otherwise the chips clog your nice new knurls.
An ultrasonic cleaner REALLY brings the details out of knurled work.
Steve
