You won't need many tools, so let's get started.
Remove these ads by
Signing UpStep 1Materials and tools
1. Aluminum can.
2. Something to cut thin aluminum.
3. Metal vent hose clamps.
4. Flat head screwdriver
I recommend:
1. Some sort of bathroom (silicone
etc.) caulk.
You can buy aluminum that comes rolled up with adhesive on one side, but:
1. I didn't need that much.
2. The adhesive might come unglued when wet.
3. The aluminum is much thicker, usually for auto body work or small plane repair.
But did you remove the plastic coating from the inside of the can first? It may not matter, but if you didn't, the caulk is bonded to the plastic, not the metal, and the plastic may seperate from the metal over time.
As long as it doesn't show up here in a few years, you'll probably be ok.
Sometimes the only taste you get in crappy American canned beer is the can itself.
This is the stuff I always buy:
http://www.motorcycle-superstore.com/ProductImages/300/0000_Permatex_High_Temp_RTV_Silicone_--.jpg
Though I just get it wherever.
