3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Method for making 3D shapes (used to make a bike fairing)
This Instructable shows you how to make a fairing (enclosure) for your bicycle/trike/etc from a combination of sheet plastic and some plumbing items (PVC and some pipe for supports). It goes hand in hand with the wind powered bicycle project that I am working on (to be posted a little later), and represents a continuation of my work on Thinkcycle. The technique I explain here can be applied to a wide variety of different items: greenhouses, fairings for other objects, sculpture, boats, etc. For vehicular applications this also forms a perfect backplane for the attachment of solar cells, etc. I'll cover how to do that in subsequent instructables.
There are lots of reasons you might like to have an enclosure on your bike: they can improve your aerodynamics, help with thermal regulation, serve as structural attachment points (for hanging lights, cycle computers, etc), but in my opinion the biggest thing is that it can provide a solution to the thing I hate most about winter biking, which is rain. At least part of the reason I have pursued this work is that there were no good options for getting my hands on a nice fully faired HPV, and nothing spells freedom like being able to get where you want to go at any time.
The basic idea for how to build this thing is to decompose your ideal shape (for the example I use an elongated ellipsoid as per some of the photos in step 2) into crescent segments using a little math (don't worry, the attached spreadsheet does all that for you, at least for the simple shape used in this tutorial). Then you can cut sheet plastic (0.080" PETG or polycarbonate) into correctly-sized pieces and then tape the outsides of them together. If you're very careful about the outline of the segments you cut, you can generate a very good approximation to the large shape you want (similar to the way the almond-shaped segments of a football are stitched together to make that three dimensional shape). Once the segments are taped together, you can fill a turkey baster up with pipe glue and run a bead of ;pipe glue along the joint. You let it harden, clean it up with a Dremel tool, and use it! For the shape I'm building, I also show you how to attach it to your bike. This is accomplished by cutting PVC T-joints in half and then using pipe clamps to attach them to the bike. The mounts have proven to be kind of tricky to get right, however, and there's some room for improvement in this department.
The motivation for this work was that I wanted to be able to make big three dimensional shapes for a number of projects but was unhappy with the existing techniques. Either they required a big oven (necessary for most vacuum and blow forming techniques) or were messy and generated lots of extra stuff (ex: cutting foam molds for fiberglassing). If you still want to go those routes, the technique I show you here can be useful in building supporting structures for use in jigs and whatnot.
The one note that I should add is that for reasons I will detail in the wind powered bike instructable (I may also call it a "Side wind safe" bike) you have to be careful about the design of your fairing if you are using a front-steered only bike (whether upright or recumbent). Basically, large fairings are unstable in high winds (so you want to keep the cross section from the side low by adding openings or making it very compact) on a regular bike. In the wind powered bicycle project I show you how to build a bicycle that will get around these shortcomings (you have to steer the front and the back wheels), but you can also attach this to a tricycle (just keep the width of the vehicle as wide as possible and the center of mass low). The fairing I build in this example is a test piece and probably too large for everyday use (although you could try cutting holes in it).
Step 1Things You will need (and some you'll just want)
Things You will need (and some you\
  • last photo ←
Materials:
PETG or Polycarbonate Sheets (you can order them from the following places: MSC, Mcmaster-Carr, Tap Plastics, Aircraft Spruce & Specialty, wick's, and probably a lot of local suppliers as well). You want the 1/16" thick stuff, and I went with 4'x4' sheets ($~20/a piece). This is the only somewhat obscure material, you should be able to get everything else from your local hardware store.
Packing Tape
Some long strips of cardboard suitable for transferring patterns
Spray paint if you're planning on painting it (optional)
Tools:
Aircraft Tin Snips (or DREMEL, etc)
Sharpie or other means of marking cardboard
Ruler and/or measuring tape (nice to have both, however).
Protractor for making baffles
Hacksaw or bandsaw for cutting PVC pipe for the supports.
Drill plus some small bits for drilling mounting holes in fairing.
A small wood rasp for doing cleanup (unnecessary if you have a Dremel)
C clamps for holding parts (at least a couple little ones) together.
Vise for holding PVC pipe.
Two options for bonding: (you have to pick one and get everything mentioned for that case):
I). ABS Glue, a turkey baster, masking tape, small bottle of MEK (methyethlykeytone), lots of newspaper, a glass jar, gloves and googles for cleanup, I would also recommend a mask: be very sure you have good ventilation. This option is essentially "chemical welding".
or
II). plastic welder (hot air, conduction or ultrasonic, you may need an air compressor if you go the hot air route) plus welding rod plus skill. This option can be a lot more dicey with transparent materials because any sort of heat distortion will ruin the transparency, but it is possible with a fed-rod design to get nice joints with it.
I decided to go with option (I) for this instructable because of the heat distortion issues (which are probably addressable with a fed-rod welder, I just don't own one). Some additional notes: ABS is not your only option for the glue base: a better option would be to use a material designed for use with PETG: I just used it because everyone has access to it and I believe it will hold up pretty well. If you want to make your own, I have elsewhere detailed some experiments using a coffee grinder to grind up your PETG cast offs and some MEK to dissolve them. I do not recommend this route unless you are really concerned with having a clear fairing on 100% of the surface (not a bad goal at all, just has a cost to it).
Knowledge:
You are going to have to be (or get! you can do this!) comfortable working with PVC pipe: both cutting and gluing it. There are a ton of tutorials online (for instance, here), so I'm not going to repeat them here, but always remember that you can do test pieces on a smaller scate to get a feeling for things. I highly recommend doing so whenever possible, you will see that for my first build I did not mask things properly and lots of the resultant joints were messy.
Optional: Dremel tool or equivalent (any small high speed hand grinder) plus tungsten carbide cutting bits (there's a photo below of the kind I like) for doing cleanup, plumb bob (you can make your own), drill press, V blocks, PVC pipe cutter. All of these tools are worth having and will make the workflow go a lot faster, but it is possible to get by without them if you're motivated to save money.
25 comments
Feb 23, 2012. 4:15 PMtoadstool says:
Man, dis stuff looks good !
Jun 13, 2011. 7:30 PMGrant-53 says:
Fine piece of work. I have been working on a similar approach for an upright bike. I use a four quadrant ellipsoid with the profile of an inverted NACA wing for some downforce. I use a skin of 1" hex mesh bonded between two layers of tarp material. The spars are aluminum angle stock attached to the frame with U bolts and the ribs are loops of 5/16" ID nylon tubing. The simple two cone version increased my cruise speed 50% and had little steering input with a 15 mph cross wind. I need to have the rear section slide or tilt to get my leg over the seat comfortably.
Feb 6, 2011. 8:44 PMnickjohnson says:
Thanks for posting all of this. I'm considering buiding the same.
Did you observe any improvement in aerodynamics? I doubt you took it to a wind tunnel, but does it at least feel more aero?
I Notice that you don't extend your fairing down to the ground. Why?
How heavy is your fairing, in total?
Jan 30, 2010. 6:28 PMNYFRAPRES says:
In actuallity the best type of glue* (*for all intensive purposes as it really isn't a glue) is a cyanopoxy.  It bonds more on a molecular level rather than on the surface of whatever you are looking to bond.  They tend to work on most any material even if they are dissimilar materials.  The one thing about them is that they are expensive.  However a little goes a long way with this product.  Cool Chem is one of the top brands on the market.
Jan 7, 2008. 4:58 PMcallmeshane says:
With the "proper" PVC primer and glue, there exists a seemingly "Oooo it's mystical stuff that resists gluing by anything" mindset... And having been sucked into this limited perspective, I believed it for a while. Having designed some portable weather and crush resistant miniature amplifier cases out of it... I was shocked to find that some joints could be "tapped apart" from just the weight of the batteries (4 x AA packs).... I mean even model aircraft glue together HARDER than this... And I had some sheet steel fall guillotine style onto some PVC grey water piping... the joint and pipe smashed into pieces... - like the parts of the joint also separated cleanly along the glue line.... Given that I have "micro" hand planed the amplifier parts into precision fits... given them a light dry sanding, had given them a good wipe over with primer and had applied a nice amount of glue to the faces and had lightly clamped the parts... I was NOT impressed... I have made harder and tougher joints with shellac and paper... So after some extra attempts to stop the batteries dropping out of the bottom of the box's... (by their own weight only) I then tidied up the old joints, and used the contact cement. The contact cement's solvent/s REALLY dissolved the top layer of the PVC... about 1mm of it kind of went really gooey - the solvent evaporated and the whole joint welded properly together. Like in engineering terms, I am not super sure and have no results from conducting rigerous scientific testing of the joints... and the combination of PVC and contact adhesive - remains a chemical mystery to me.. and what the joints will be like under fatigue and time testing.... But the arbitrary tests of big muscles and close examinations etc... tell me that the PVC joints, welded with yellow cack contact adhesive.. ARE really strong, tough, not brittle or crackable, and they ain't coming apart... Yet all the properly prepared and glued joints, using the REAL PVC pipe glue and primer, could be peeled apart, broke cleanly under impact and fell apart in tension. I'd post some macro-photographs - when I have the time....
Oct 15, 2008. 8:59 AMmacrumpton says:
Gluing PVC is a piece of cake, if you want a real challenge try gluing polypropylene. I have been messing with Coroplast (like a polypro cardboard) for almost 4 years and I have found exactly 2 ways of reliably sticking it together: 1 Mechanical fasteners: rivets, bolts and for temporary joints: tape (esp gorilla tape) 2 heat sealing with a hot air gun or plastic welder. The heat sealing is harder, but once you get the technique it is very strong. I wish there were a glue that worked 1/2 as well as the heat sealing.
Sep 23, 2009. 6:51 AMjeff-o says:
3M makes an adhesive specifically designed for plastics like PP that can't be glued with anything else. It's pricey though.
Jul 29, 2008. 12:09 PMAdrianReef says:
what if you smash yourself on someone else's car ?? I mean...what is the pain a vehicle of this kind can make to a human driving it ??
Jul 31, 2008. 7:23 AMAdrianReef says:
due to the number of cars on the streets It's rather difficult to be hit by one of these :-P ...so...I'll probably choose to be hit by a car this time !!! LOL anyway...jokes apart...I was trying to underpin the conversation on the dangerouness of the design. For example...your neck,in the image, seems to be very exposed in a possible collision with the enclosure , and we all know how painful a neck blow can be :-/ pay attention...I'm very pleased by your job..this instructable is awesome !! I'm only trying to give you some suggestions on the safety side of the vehicle ;-) no claims here :-P Best Regards - Adrian ;-)
Mar 24, 2008. 10:13 AMcjbikenut says:
Very cool I would really love to see more current photos as well as info on your bike. I've been collecting bike frames and such to build SWB recumbent commuter.
Mar 24, 2008. 11:48 AMcodester says:
I need to make one of these.........
Jan 6, 2008. 9:14 PMcallmeshane says:
Sumfing you may wish to find out... I have used the "proper" PVC primer and glue and I have busted up a few things made from it.... It's crap. Best glue I have found is the Ubiquitious (pick own brand name) mustardy / yellowish contact adhesive. (Sellys, Bostik etc) It really dissolves the surface layers and makes for a TOUGH and impossible to get apart joint. And if the joint is smashed the glue won't allow the parts to separate.
Jan 4, 2008. 5:54 PMdbarr15 says:
will the spreadsheet work with different size sides(segments) keeping the length the same
Jan 6, 2008. 6:33 AMdbarr15 says:
What if I wanted different segments to be different widths that would all come together. Could I just plot the curves for each width with everything else being equal?
Jan 1, 2008. 10:57 PMtrebuchet03 says:
What 'bent is that? I expect coast down tests within the next week :p Kidding Nice work :) Out of curiosity - does the rear portion of the fairing deflect much given the long PVC supports? I imagine if the fairing itself weighs too much, the bending moment would be significant (a problem I had with a cardboard fairing and super weak support) :) I added the HPV keyword as I have some related projects up with respect to fairing construction.
Jan 1, 2008. 9:53 PMBobS says:
Interesting project! My only reservations are about durability: wouldn't the plastic become brittle soon, after exposure to temperature differences and UV? A bike sometimes falls over, or bumps into things while parking.......
Jan 1, 2008. 5:37 PMrimar2000 says:
Awesome, Vincer. Good work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Vincer
I'm an applied physicist/mathematician with an interest in checking global warming.
