loading
Step 7: Free-fall Spinners
Spinning objects that can be used inside a support tower.
<p>how long did that take to make its awsome</p>
<p>nice.</p>
0_o How have I not found you before?! Subscribed xD
Can you post this one
Can't you make it from the pictures? It's not that hard, really... :P
<p>I built zigzag!</p>
Yeh probably
<p>It'd be awesome if you made a step by step instruction on how you made each piece and then put it all together. Hell...I'd pay for it.</p>
Thank you immensely for the credit!
can you post the big ferris wheel??
I already took it down but here's a large picture of it:<a href="https://www.instructables.com/files/orig/F8O/MHBP/GGC2TVJQ/F8OMHBPGGC2TVJQ.jpg"> link<br> T</a>here are a total of six white connectors in the center of it.
I built it but yours seems to spin faster than mine
he ik ben ook nederlands. heb jij fotos van het platform ?
wish i hade that much pieces
Im so using it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! <br>=^..^= (cat).
Do you know if it works with the Black/White balls?
IMNO HELP TO YOU
O.o Btw i tested this a while ago and they work on this :p
Can you also use a big gear instead of 2 medium?
try it
Do balls ever fall off the ball machine?
Nice job I really like metropolis it has helped me come up with ideas for my ball machine!I don't need help with the path Deviders anymore I was able to make my own!
hi I was wondering if you could give instructions on how to make your path deviders?I like them a lot!
Cool, I use that track a lot so that will help.
good
Oh god I haven't been on instructables in a long time haha :D Sometime last year.
wow
I'll come back...been doing a lot of YouTube videos since I got an amazing computer :D
&quot;Version blue with blue rods&quot;. I think you meant version two with blue rods
Yup, edited :)
Version blue sounds better
It probably does but I was just following the pattern. The coolest would be version white is with white rods and version blue with blue rods
Makes Sence
Cool, btw could you make the video so that you can watch it on iPod iPad and iPhone. I think you do it on settings from YouTube from your computer<br>
how do you build the middle panel in the tower? and how do you install them
I just used a lot of white connectors instead of rods, to reinforce the tower.
is the middle necessary??
Nah, it's just for looks. You can just use a normal frame.
every time i put the motor directly on the axle and turn it on, the wheel turns really really fast not like yours in the video, what do i do?
You can reduce the speed with a small gear on the motoraxle and a large yellow gear on the wheelaxle.
thax
It also makex the strength of the motor bigger
On the wheel lift, is it necessary to have the one side made of solid snowflakes, or can both sides be made of the blue rod frame?<br><br>
Sure, you can have it open on both sides. Also the remaining side does not need to be filled with snowflakes. If you replace half of those with blue rods, or 3/4th with red rods, it will probably still work!
Awesome, thanks very much!<br>
But the snowflakes make it stronger and sturdier.
How many white connectors did you use for the floor
Gravity must be different in the Netherlands because I needed a larger weight for it to work... :-?
It is possible that this could be (there are places in Canada that have less gravity,) but not as likely. More likely, as time went by in the Knex world, the company figured out how to make the pieces lighter and lighter, so maybe you're using the older pieces?
How can gravity be different in the Netherlands? :-P Maybe your ball machine is unlevel.
About This Instructable
24,000views
24favorites
License:
More by Kairah:Metropolis - Knex Ball Machine Elements and Lifts Metropolis - a K'nex Ball Machine Fort Kecil - a Knex Ball Machine
Add instructable to:
