Miata Trunk Opener - Lock Mechanism Failed Leaving the Hatch Stuck Shut
3,302
5
Published
Introduction: Miata Trunk Opener - Lock Mechanism Failed Leaving the Hatch Stuck Shut
Today I went to help my dad with his 90 Mazda Miata. As it turned out the trunk was stuck shut because the lock mechanism failed. By design there is no backup to accessing the trunk in the event the lock mechanism fails. I will show you how to open your trunk in just a few easy steps without damaging anything in the vehicle.
Step 1: Removal
First step is to remove the 3 items that block your ability to access the inside of the trunk.
1. Passenger Chair (Quantity 4 - 14mm Bolts)
2. Peel back the carpet
3. Remove the rear firewall (a dozen or so small 10mm bolts)
Step 2: The Tunnel
View the passageway/tunnel you will use to access the trunk. This is to the passenger side of the gas tank.
Step 3: Handy Dandy Trunk Opener
Now its time to make the tool that you will use to release the latch.
You will need the following items
1. crowbar
2. flash light
3. 2in x 2in x 4ft long piece of wood
4. masking tape
Tape the crowbar and flashlight to the end of the piece of wood and voilà you have a new handy dandy tool.
Step 4:
Using the new tool you will first need to pull the carpet in the rear of the trunk down to expose the lever for the rear trunk release. Once you have done that you can use the forked part of the crowbar to pull the arm for the trunk lock release.
Step 5:
Voilà you now have an open trunk so you can fix whatever it was that broke.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    3 Comments
    This is excellent. Thank you for sharing.
    We had an incident last winter in a deserted and unfamiliar area with a dead battery. When the battery (which as you know is located in the trunk) is dead, the latch release button will not work. Domino effect in motion. The jumper cables were in the trunk. Using the 25 year old key in the cold weather to open the trunk, the key finally decided it was ready to retire and broke off in the tumbler. My husband now called is on his 1 1/2 hour drive to me with the spare key and one stop off for new jumper cables. Of course Mazda didn't plan ahead for suck a domino effect, so they did not create posts on the engine for direct engine jumps, but hubby was brilliant and found a way.
    I have since been told, the trunk release cable fails often on older Miata's. It becomes stretched and worn over time. With our experiences and your ingenuity in mind, I am now wondering what could be rigged as an emergency pull cord to permanently remain somewhere inconspicuously but accessible when or if the need arrises.
    Great work! Glad to see you got it open. Was it an easy fix after that?
    Until I can purchase a new lock cylinder I am using a fishing leader that has clips on both ends and which was extremely to connect and seems to be working just fine as a temporary release lever.
