3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mic Stand Camera Mount
On a recent show, I needed to have a view of the stage. Normally there's plenty of room to put a tripod up at the back of the room and have a camera send me a feed of what was happening. In this particular venue, there was no extra space at the back of the room, and no room for a tripod.
What I needed was something stable with small footprint that I could slide between two seats and not take up any space in an aisle. I spied a microphone stand on stage, which was just what I needed. The remaining obstacle was to figure out how to mount a camera to a microphone stand.
Cameras come with a 1/4"-20 hole in the bottom to affix a tripod or a shoe. Microphone stands use a 5/8"-27 thread for mounting clips and goosenecks. Hmm. 1/4"-20 is common... but 5/8"-27 isn't and I figured I wouldn't find "just the right thing" so I set off to the hardware store.
Step 1The Pieces
The Pieces
My criteria was simple: my solution had to be small, attach securely enough to the mic stand to allow the camera to stay in position and not fall off if it got nudged. Oh, and cheap and easy. I had limit tools and no desire to dump a bunch of money on an untested project.
After wandering through the local hardware store, I came up with the following list of pieces to fashion my camera mount.
A non-threaded female-to-male threaded adapter for 1/2" PVC
A threaded PVC cap that fit on the previously procured adapter
One each 1/4"-20 nut, wingnut and 1-1/2" long bolt
The minimum purchase (12" in this store) of 5/8" ID flexible water hose.
I probably could have done this with just the non-threaded version of the PVC cap, but I figured that building it this way would give me a way to interchange caps that might have new and different purposes in the future.
8 comments
Feb 2, 2009. 11:39 PMappsman says:
How's this for irony? The Zoom H4, a pretty nice handheld digital recorder with built in stereo mics, has camera mount threads. So this is exactly what I need to mount an audio recorder on a mic stand! Whoda thunk it?!
Feb 25, 2009. 9:50 PMcosmicdog says:
Even more ironic...the cheaper Zoom H2 includes a mic stand adapter, while the H4 doesn't. Apparently, the new Zoom H4n does include a handy mic adapter. I guess I bought mine too early. Darn. This project makes me happy, though!
Jan 8, 2011. 4:34 PMkyletleach says:
Just used the H4n last night. The "mic adapter" is more like a tapered finger that slides onto the stand like a tapered handheld mic would. not very secure looking if youre planning on booming above people's heads!!
something like this instructable looks much more secure!
Oct 9, 2010. 8:35 PMfantasticsound says:
Interesting. I love DIY versions of many items, some of which are unavailable from manufacturers.
This, however, is readily available through camera supply houses, etc. A sturdy, compact metal version is available for $7 or $8 and a ball & socket pan/tilt version is available for $13 from Musician's Friend. I salvaged a work box containing two adapters, the first adapting the standard U.S. mic mount to the smaller, European mount. The second adapts the European mount to the standard camera screw mount.
DIY is great for convenience and saving money. In this case, however, I don't see why you wouldn't buy the commercially available solutions.
May 20, 2009. 10:13 PMqpix555 says:
Awesome idea i may adapt this to the camera pole mount i am building........
Jan 28, 2009. 3:58 AMdoo da do says:
nice idea, seems to be simple and easy to make
Jan 26, 2009. 7:43 PMguitarman63mm says:
I've actually stuck my camera into a shock mount (I know some cringe at the notion...) to keep it stable while on a boom arm. Worked pretty damned well, if I do say so myself. However I'm probably going to end up making this once I finish my other projects. Good 'ible!
Jan 26, 2009. 7:06 PMbruno13069 says:
Grab a microphone stand with a boom arm. Unscrew the microphone clip and put that end about 2" above the elbow. This should allow clearance for the camera to move as much as possible. Adjust your height with the base, and the angle with the boom arm. The camera should not move outside the center of gravity range for this mount. If you think it will, weight down the base of the stand. Don't forget to replace the microphone clip. Great Instructible!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mnwingnut
