Step 6The Pudding
One you've cut the tubing flush with the adapter, assemble to the two pieces of PVC. Hand tight is fine...the threads are tapered, so you don't go too many revolutions before you've achieved a tight fit.
You can now thread the assembly onto a microphone stand. Sure, you could just push it down, but I twisted it into place so as to not mess up the threads of the mic stand or rip up the tubing on the threads.
Once it's on the mic stand, you can mount your camera. Spin the camera onto the the bolt until it bottoms out, the back the camera off about an 1/8 of a turn. Spin the wingnut up and tighten it against the camera.
Now here's the only downside to this design. You can adjust height and you can adjust the pan. Angle adjustments are limited. As you can see, I'm using this for a Pan-Tilt-Zoom camera which gives me lots of latitude. If you need more tilt adjustment, you can either install this device on a boom arm or you can buy a ball mount and mount it onto the cap.
But for less than $4.00, I had a nice, secure, portable camera mount to use with a mic stand.
comment
Add Comment
Add Comment
