Mic stereo with little amp in a pencil box
  • last photo ←
Mic stereo with little amp in a pencil box, i build this for my project http://www.archivosonoro.org is a non-profit project about the Soundscapes and Field recordings. This box use with a MD-510n Minidisc recorder with Analogical IN.
Happy build!!!
Step 1Parts
Parts
The goal of this project is reuse and use cheap parts, well in my country (Mexico) are a Shops with articles from China (China everywhere!!!), in this kind of Shop buy a metal boxes pencils (and other wondefull and usefull things for Build, Make and enjoy the DIY).
From my garbage electronic:
2 transistors NPN BC548 (experiment with others if you like for example: 2n2222, c1056, etc)
1 Jack plug Male Stereo
1 Switch
2 Electrec mic
1 Little piece of hose transparent from my old Acuarius Tank
1 Battery holder 2 AA
Various screws, and hole drills.
57 comments
1-40 of 57next »
Nov 12, 2010. 6:21 AMkhushal_kkk says:
do this circuit works for a stereo system , like i designed a system in which 3.5mm stereo jack is used and i use to connect it to computer to listen song through speaker do this mic work with it if i talk in that would i be abble to transmitt my voice through this designed stereo mic.
Nov 7, 2010. 11:58 PMNeoFusion says:
i cant understand the circuit well, hmm why is that there is only 1 electret mic on the schematic? help here total noob and i want to make your project badly!
Jul 15, 2008. 2:50 AMOimi says:
I'm confused, is this an amp or a sound recorder?
May 25, 2008. 2:20 PMGorillazMiko says:
Awesome! Very easy, kind of, nicely done, very cool. I might try this out if possible. +5/5 stars.
May 25, 2008. 4:36 AMstevie1 says:
to make it more "beatifyl" u could use a pc board just a thought
May 25, 2008. 1:28 PMstevie1 says:
yup. =)
Mar 20, 2008. 3:35 PMbaruc says:
hola se ve muy bien, y como apenas empiezo en esto de la electronica lo he hecho en un protoboard, no copie el modelo de el ultimo post, porque use más bien tres resistencias en serie que me sumaron 480k en lugar de la de 470k, y use un transistor 2n2222A, ahora, el mic. sólo lo probe y si funciona, pero ya en el circuito cuando lo conecto a mi grabadora de voz(panasonic) o a mi lap, me entra un ruido muy fuerte como de interferencia, como un tiiiiiii... nose que pueda ser. me surgio la pregunta de para que me sirve entonces, talvez no necesite un preamp.. nose podria explicarme como lo puedo ocupar, y porque crees que tengo ese ruido? gracias.
Apr 8, 2008. 11:28 PMbaruc says:
gracias por responder. probare más y te escribo de nuevo igual con una foto de mi circuito. saludos
Jan 4, 2008. 3:29 PMtruax says:
can anyone see something wrong with my circuit? i've tried all sorts of stuff and it won't work.. help!
Jan 5, 2008. 12:21 AMtruax says:
and i'm guessing the ground for the mic also should also be hooked up to the negative?
Jan 5, 2008. 10:59 AMtruax says:
hmm. something is still wrong. is it necessary to be using the BC-548 transistor?.. i have here the 2n2222.
Jan 5, 2008. 1:16 PMtruax says:
Thanks! it works now.. i'm a total newbie at all of this.. barely passed my first college class. It turns out I had the emitter and the collector switched around.
Jul 27, 2007. 10:18 AMdannydutton says:
Ha! If you were to some how eliminate the tubes coming form the box and put the switch and a tiny tape recorder inside too then you would have a really cool bugging device.
Jul 22, 2007. 9:32 PMmrwizardgi says:
total noob here so i apologize up front...what would the db rating on these things be? meaning how loud could something get before you notice distortion? are these mainly for 'normal' everyday sounds or could i take these to a concert and make a live recording? again, i'm a total novice in all of this so any info would be appreciated. thanks! peace j-
Jul 23, 2007. 10:55 AMmrwizardgi says:
thanks so much! this looks really cool and i look forward to trying it out! thanks j-
Jun 21, 2007. 12:33 AMBotfly says:
Your wonderful project was the first I came across in my search, Llaven. I have since found more that may be of interest and use to you and others.
Monkeyphones
DIY Stereo Mic Rigs
Quiet American - Links
Rane - Selecting Mic Preamps
And there seem to lots of places from large stores to single guys in a shop who basically sell these fully constructed with a preamp. Price vary from ~$50 to $600 US. The capsule prices don't seem to vary all that much from what I've seen but there's a bit of work to find a pair to match so they sound good as a stereo pair in terms of gain and frequency and then various custom tweaks. I can't really comment or plug any of the following as I am still doing research and have not tried any but do a search on Core Sound, Church Audio, Sound Professionals and Squid Audio.
Jun 29, 2007. 6:24 PMSacTownSue says:
Botfly, thanks for the links llaven, thanks for the project. This is an excellent beginners project. I noticed that you posted this about 7 months ago and it's the only project of its kind on instructables. wow ? it looks like the only thing you are using the screw and washer for is to hold the plastic tubing in place. It seems like you could accomplish that with tape or glue. Or am I missing something?
Jun 29, 2007. 7:51 PMfirewire says:
awesome
Dec 4, 2006. 7:38 PMelectronicfreak22 says:
Awsome instructable. This might work in an Altoids tin.
Dec 9, 2006. 7:13 AMerevos says:
Damn! You guys really love those Altiods tins!!! Too bad we don't have them here in Greece... :(
Jun 29, 2007. 6:27 PMSacTownSue says:
maybe you should start importing them. Become a distributor. I buy them on sale at Walgreen's 2/$2. $1 a tin and free gum or mints. can't beat it!
Apr 21, 2007. 1:28 PMJames (pseudo-geek) says:
I'll send you some for $500 each.........lol
Apr 21, 2007. 1:30 PMJames (pseudo-geek) says:
BTW the modern term for "microfared" is uF not MF. nowadays MF means megafared.
Apr 21, 2007. 1:31 PMJames (pseudo-geek) says:
but aside from that minor detail, I think I'll build one, it looks like loads of fun. does it proccess the sound to where you could hook it right up to a speaker?
Apr 4, 2007. 7:11 AMdrab says:
do you know a good bgeinner's guide on the net for learning how to read schematics etc?
Mar 21, 2007. 2:54 AMBotfly says:
Stereo Microphone Techniques (About.com) is a decent article with an explanation of popular microphone configurations (x/y 90 degress, ORTF, a/b), when to use them and photos.
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:llaven
Visit my site www.emilio.com.mx
