Michiels Knex Rubber Band WITH Ammo Gun
1,101
15
Posted
Introduction: Michiels Knex Rubber Band WITH Ammo Gun
Also Check Out My Other Instructables:
- My Knex Wii Zapper: https://www.instructables.com/id/Michiels-Knex-Wii-Zapper/
- My Knex Battle Bot: https://www.instructables.com/id/Michiels-Knex-Battle-Bot/
- My Knex Wii Wheel With Auto-Centering: https://www.instructables.com/id/Michiels-Knex-Wii-Wheel-With-Auto-Centering-V1/
- My Knex Shell Ejection Gun: https://www.instructables.com/id/Michiels-Knex-Shell-Ejection-Gun/
Hi Guys,
This Is My Knex Gun. It Uses The Rubber Band Mechanism BUT It DOES Fire AMMO! A Gun Using The Rubber Band Mechanism Only Fires Rubber Bands. Here Is Some Information:
A Short Video:
http://www.youtube.com/watch?v=sMMfcUPiokw
PRO'S:
- The Mech Itself. You Can Shoot Many Bullets Without Reloading, 'Cause You "Pre-Load" The Gun. You Load Each Rubberband And Afterwards You Can Shoot Them Without Reloading After Each Shot.
- The Magazine Is Easily Removable.
- You Can Actually Fire As Many Times As You Want, Still I Recommend Loading Only 12 Rubber Bands.
- You Can Fire Really Fast.
CONS:
WITHOUT UPDATE (=LAST STEP) :- Sometimes Something Jams.Usually It's A Rubber
Band.
WITH UPDATE (=LAST STEP): -Doesn't Jam Any More/At All. So No More Cons.
PARTS LIST:
RODS:
- Green Rods: 131 +1 For Each Bullet.
- White Rods: 69
- Blue Rods: 25
CONNECTORS:
- Gray Connectors: 20
- Gray Connectors with 2 Teeth: 8
- Orange Connectors: 9 +1 For Each Bullet.
- Red Connectors: 25
- Green Connectors: 21
- Yellow Connectors: 44
- Blue Connectors (7 Teeth): 2
- Snow Flakes / White Connectors (8 Teeth): 16
- Tan Connectors: 4
- Small Blue Connectors (Smaller Than Single Teeth Gray): 3
- Black Connector: 3
OTHERS:
- Blue Spacers: 42
- Gray Spacers: 11
- Rubber Bands: As Many As You Want.
If You Have Any Question Or Problem Or Something... Just Leave A Comment, I'll Help You.
Step 1: The Gun Part 1
This Is How To Make The First Part Of The Gun.
Picture 1: Make This.
Picture 2: Make This.
Picture 3: Make This.
Picture 4: Connect The Pieces So You Get This.
!!! MAKE THIS TWICE !!!
Step 2: The Trigger
This Is How To Make The Trigger.
Picture 3: Connect The Pieces So You Get This.
Step 3: Middel Parts
This Is How To Make The Middel Parts.
Picture 1: Make This Part 3 Times.
Picture 2: Conntect The 3 Parts With A Blue Rod.
Picture 3: Make This 3 Times.
Picture 4: Connect The 3 Parts With A Rubber Band.
Picture 5: Make This And Check The Quantitys.
Picture 6: Add The Blue Rods Like This.
Picture 7: Add The Blue Rods Like This.
Picture 8: Add The Blue Rods Like This.
Picture 9: Put This Blue Rod,
Picture 10: In This Orange Connectors "Hole".
Picture 11: Now You Got This.
Picture 12: Add This.
Picture 13: Add This.
Picture 14: Add The Blue Spacers.
Step 4: The Gun Part 2
This Is How To Make The Second Part Of The Gun, It's Connecting The External Part.
Picture 1: Connect Like This.
Picture 2: Connect Like This.
Picture 3: Connect Like This.
Picture 4: Current State.
Picture 5: Add A Rubber Band. At The Other Side Of The Gun, Connect Also Like On This Side.
Step 5: The Magazine
This Is How To Make The Magazine.
Picture 1: Make This TWICE.
Picture 4: Add Blue Rods With Spacers.
Picture 5: Connect The Parts From Picture 2 And 3.
Picture 6: Break The Other Part From Picture One Down To This, Now It's Easier To Connect It.
Picture 7: Connect The Side Pieces Like This.
Picture 8: Connect The Middel Part Like This.
Picture 9: Add A Blue Rod With Spacer Here.
Picture 10: Make Both Pieces TWICE.
Picture 11: Add 1 Blue Spacer On Each Rod. (So That's A Total Of 4 Blue Spacers.)
Picture 12: Connect The Pieces From Picture 10. And Don't Forget To Add Those (2) Tan Connectors.
Picture 13: At The Other Side Of The Magazine, Add (2) Blue Spacers.
Picture 14: Add The 2 Pieces From Picture 10. And Don't Forget To Add Those (2) Tan Connectors.
Picture 15: Make These Pieces. Mind The Quantities.
Step 6: Loading
This Is How To Load Your Gun.
Picture 1: Put As Many Rubber Bands As You Want Here.
Picture 2: Pull Each Rubber Band Back And Release It Like This
Picture 3: Put The Magazine On Like This And "Blok" It With That Red Part.
Picture 4: Put Your Bullets In Like This.
Picture 5: Put The Thing To Hold The Bullets Down In The Magazine.
NOW YOU'RE READY TO FIRE!!!
Step 7: Update
This Step Is About An Update I Made While I Was Making This Instructable. So In That Time I Found Some Improvements, They Are Easy To Make.
Picture 2: Connect The Piece From Picture 1.
Picture 3: Add A Blue Rod With Blue Spacers. These 2 Spacers Are Important!
NOW YOU'RE DONE, I HOPE YOU LIKE IT
And If You Have Any Question Or Problem Or Something... Just Leave A Comment, I'll Help You.
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    16 Comments
    nice!
    You say "nice!" for every instructable I have seen your comments on, including mine!
    i know... im leaving ibles soon =D
    I know. I just saw your comments and they said you were sellin' your k'nex! How much? £100? Do you take UK money? You could go to the foreign exchange bearau and get it changed.
    yes, thats true, i could yes, itll cost alot of money to post it beacause its 6500 parts which is like 20kgs lol, ill have to put up a bid on ebay sometime =D
    That's been done before with a better magazine.
    I say again, that isn't a new mech or idea.
    I Didn't Say This Is A New Mechanism, Me Too, I Also Found A Gun Using The Same Mechanism. Anyway, Can You Please Post Some Links To Other Knex Guns Using This Mechanism. I'd Like To Check Them Out! So Maybe I Can Improve My Gun. Greets!
    Pleast Stop Talking Like This It Is Stupid Please talk normally you look weird.
    Well you look "weird" because I believe it is spelt "Please" not "Pleast"! so there! :P
