3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Micro Processor Chess Set
Rather than play the computer chess, why not make a chess set out of the computer!
This is version 0.1 (beta). If I can get enough Pentium "586" chips, I'd like to make a regulation size chess set.
Any constructive criticism would be appreciated!
Step 1Chess Board
Chess Board
The board is the underside of a mother board, and 32 black microprocessor chips.  This creates the colors Green vs Black.  Each chip was attached with epoxy.
The principal hardware was left on the bottom side.  Legs for elevation are bolts press-fitted into the chassis mount holes.
All subsequent pieces were painted green or black, if necessary, to indicate side.
49 comments
1-40 of 49next »
Mar 9, 2010. 6:30 AMfazgard says:
Very cool.
GOnna have to empty out some spare parts bins this weekend and make one!
Oct 8, 2011. 4:04 PMpfred2 says:
Board manufacturers wash boards after assembly in water. They expect new components to function after doing so as well. Place I worked for actually used a dishwasher to clean the water soluble flux off the PCBs after we ran them through our wave solder machine.
Trick is to just let everything dry out and it is fine.
Jun 15, 2010. 10:00 PMshdsteel says:
how do you remove the microprocessor chips?
Oct 8, 2011. 3:57 PMpfred2 says:
To desolder quad flat pack packages you can just blowtorch the back of the board and they fall right off. It does stink to the high heavens when you do this though! So it isn't an indoors friendly activity. Some use toaster ovens or frying pans for doing this too. I bet even a barbecue grill would work. Then a big empty cardboard box to catch the hot parts is used. This method is called the, "heat it and beat it technique". Because after you get the boards hot enough you quickly slap the boards against the inside of the empty cardboard box to dislodge as many parts as possible into the box.
It goes without saying you hold the board in big pliers and wear gloves to protect yourself from the high heat. Safety glasses are stylish as well to protect your eyes from molten globs of solder that can go flying. Most stuff ends up in the cardboard box though.
Pro tip: after you've slapped the board a few times into your cardboard box transfer the parts to another box, or tray or something so the little molten solder balls don't end up on your parts so much.
Jul 26, 2011. 1:49 AMaliyevzaur1989 says:
Creative , but a big waste of such nice components :((
Oct 8, 2011. 3:41 PMpfred2 says:
Maybe the parts are burnt out? I'd like to think they are myself.
Oct 8, 2011. 3:18 PMlookwhatjoeysmaking says:
this is sooooooo cooollllll i wish i cold find all the parts to make this .
Jul 22, 2010. 10:54 PMhopekiller30 says:
i just wanna know y u would take apart computers just for the parts if like the board went beep everytime u moved that would of been ok or if it said the position u put it at that would be cool but y i bet those computers wanted to go onto the internet one more time before u ripped them apart
Nov 28, 2010. 5:16 PMhopekiller30 says:
ok. just to remind u that u can always make it beep or say "A1" or something like that can always be done.
Jun 27, 2010. 12:55 PMshdsteel says:
what brand and style of paper shedder was it?
Jun 13, 2010. 9:08 AMshdsteel says:
looks greatly stupendous! where did you get the motors?
Jun 15, 2010. 8:20 PMshdsteel says:
ok thanks! and what about the heat sinks?
Mar 9, 2010. 9:34 PMdanlab says:
I love the idea, partially because nobody else will have a chess set quite like you do. It's just too bad it's to late for you to enter it in the Dead Computer Contest. And I think you're right, it would be better with bigger squares, but It is still a great project, keep up the good work.
Mar 8, 2010. 11:34 AMlemonie says:
Very nice.
L
Mar 9, 2010. 12:02 AMlemonie says:
The Chess board is a representation of a battlefield, "a bit crowded" and I'm looking at a fight in a nightclub up there. I agree that these would show better spaced out a bit more, but they still look good as pieces.
L
Mar 10, 2010. 1:21 AMlemonie says:
Yes these bigger-socket chips are more like it, but less easy to get a bag of I should think?
Another idea might be to get a red and a green PCB and cut squares out of them?
L
Mar 8, 2010. 11:28 PMXOIIO says:
Freaking brilliant!
Mar 9, 2010. 12:27 PMknektek says:
at the bottom actually have a power source, so that when the pieces are on the spots, they light up.
Mar 9, 2010. 2:23 PMnickodemus says:
Awesome. I especially like the bishop in the third picture.
Mar 8, 2010. 11:21 AMjeff-o says:
I like it!  Very clever.
Mar 8, 2010. 9:57 PMjeff-o says:
I've seen motors far larger than that pulled out of old computer equipment!  The company I worked for recently trashed an old 350MB external hard drive.  It was the size of a dishwasher, and used about 2kW of power when running.
So yeah, you're fine.
Mar 8, 2010. 6:15 PMLindie says:
Really nice!
Mar 8, 2010. 12:44 PM=SMART= says:
Looks awesome !
Great attention to detail !
a few great projects missed the deadline by a hairline, they should extend it a day !
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:CrLz
CrLz : Ideas, ideas and ideas - Love it when I get one hammered out and working. Seems like there is plenty of room for creativity, in between cheap goods and expensive solutions, and beyond those ...
more »
