Remove these ads by
Signing UpStep 1: Ingredients
- 2 (or more) spring clamps
- a "stick"
Spring clamps like these are available at every hardware store known to man, and any self-respecting, hardware-selling website. They cost anywhere from <$1 to >$5, depending on the brand and size you get. I use Bessey 2-inch spring clamps. Not because I'm attached to the brand; just because that's what my Lowes' carries.
For a stick, you need something thin enough to fit within the jaws of the clamp, and thick enough to maintain friction within the jaws of the clamp. To qualify the first part of the above statement: the larger diameter the stick is, the closer together the handles of the clamps will be, and therefore the narrower the base of the "sawhorse" will be.
I use a 1.5-inch dowel with my 2-inch clamps.
Visit Our Store »
Go Pro Today »
Fortunately we're also not talking about a very high work surface either, so Science! dictates that the potential for wobble is fairly minimal. I'm sure you could shore them up in various ways if you're particularly concerned with stability, but that would detract from the simplicity, speed and convenience of the design, and in most cases* not be necessary. If someone comes up with a quick, simple, and clever solution to this potential quandary, I'll be happy to add it or add a link to it.
*"most cases" is an unqualified blanket statement. It may be that the next time I use this rig I'll revise my heretofore unchallenged assertion, and I will have to post a retraction. Only time will tell.
