Micro USB Upgrade for Standard Flash Drive
6,423
145
21
Published
Introduction: Micro USB Upgrade for Standard Flash Drive
Upgrade your old not cool and not mobile friendly flash drive to micro usb monster. :D
Step 1: Tools
Step 2: Opening
Step 3: Wiring, Soldering and Closing
This was easy, just grab some thin wires and solder them at the usb pinout, better would be solder them directly on chip but i was too lazy for that.
Edit: Added usb wiring, if you have cable with some weird colors use multimeter. ;)
Step 4: Finish
Now just close it, add some hot glue and use heat shrink tube for finalize.
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    21 Comments
    looks very cool. well done.
    Having said that, I bought a small adapter that takes USB sticks and 2 sizes of SD cards and plugs into my phone for 1.99.
    For that price it is hard to beat :-)
    could you post a link for this?
    This is the one. plugs in a phone with micro USB, takes USB stick, microSD and miniSD (or is mini SD the regular size nowadays? i kinda lost track).
    bought it at 'Action' a local thriftstore
    Added wiring scheme and picture how ugly it looks without heat shrink tube. :)
    The reason it won't work is because USB needs power and that port won't supply power to make it run as far as I know
    And whats your point ? Every mobile phone which support usb host has 5v output on USB. ;)
    As far as i know, you need to enable usb host mode before connecring something...that means that has to be a pre-wire into OTG/HOST mode.
    Work's like a charm on Samsun galaxy note 2, no needs for additional wiring
    Just to let you all know this won't work I have a better way of doing this without the need of soldering the device I use is USB port on both sides like connecting a USB to the wire without soldering sad to say I plug it into a android and it don't see the drive other wise I would have a 32GB port
    Great idea, but this could use a little more, step by step, detailed written instructions, for those of us who are more technically challenged.
    I will cut the heat shrink tube and open that again to update the lastest steps. ;)
    Add a keyring and its perfect.
    awesome could definitely be useful, maybe shorting the wire a bit might be a upgrade. maybe remove entirely.
    Yeah, you can definitely solder micro usb cable directly on flash drive, but i had only this short usb otg.
    So cool! I'm sure this comes in handy instead of needing an adapter. Thanks for sharing and congratulations on your first instructable!
    contest.
    If you do respond to this comment so I can vote :)
