Micro Knex Gun
PlayK'NEX by
Introduction: Micro Knex Gun
This is my first instructable so I decided to start small; A micro knex gun that will fire the tiny green rods or BB pellets.
Can I just say to people that this gun is not meant to fire far or hurt - it is just a very lightweight and small stealth gun.
Step 1: Parts
you will need:
1 rubber band
1 yellow connector
2 white connectors
3 orange connectors(mine are dark brown)
1 grey connector
3 grey rods
2 yellow rods(mine are dark grey)
1 blue rod
Any form of projectile(I have 3 green and 1 black little rods)
Step 2: The Frame
don't even think about asking for writen instructions,any one can do this step!
Step 3: The Main Body
once again just build what you see in the picture.
Step 4: Other Parts
this is the pin and trigger
Step 5: Assembly
Push the body onto the frame.
Place the trigger on the left sticking out bit if you are firing from your left hand or on the right if you are using your right hand.
Then slide the white piece up the frame to hold the trigger in.
Step 6: Last Step
Pull the trigger to the side and slide the firing pin in the back of the gun.
Stretch the elastic band from one brown connector to the firing pin then to the other one.
Step 7: Loading and Firing
To load:
Pull the pin back and the trigger will fall in to place.
Put a green rod into the hole at the front of the gun.
To fire:
Rest the two yellow rods in the palm of your hand,lift the trigger with your tumb and the firing pin will hit the greenrod firing it silently out the end of the gun.
Step 8: My Next Gun
what do you think of my knex missile luancher
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    i put a yellow firing pin in and it it goes through the barrel
    lame side trigger look at some of my gunstrue triggers. look ate my newest gun. the skorpion smg.
    i made this using micro knex and using an adapter added it as an under barrel attachment for my semi auto p90. shoots pretty far and with enough rubber bands does some actual damage. very nice build for what parts u had.
    Can you have any other part besides the white connector because I only have one
