Mics are interchangeable in this blimp (if the mic's diameter will fit inside).
Remove these ads by
Signing UpStep 1Materials
Paint roller from Walmart ~ $2.25
Scrunchie hair elastics ~ $3
Sink strainer from Bed Bath & Beyond ~ $4
Microphone(s) (assumed you already have these)
(Materials not shown)
Five feather boas from Michael's craft store ~$10
Epoxy
Black thread and needle
paint roller extension pole from Home Depot ~ $16
http://www.martelelectronics.com/288.html
SafeandSound Mastering
mastering
http://www.fcc.gov/cgb/wirelessmicrophones/
Do not buy any that fall within that range, unless you don't plan on using them after that date.
I now give lessons before handing out a hand held.
Just one question minniesfarm- Do you really know what all those knobs do? ;-)
Filmmakers like me use a shotgun style mic, which records sound from all directions.
Shotgun mics are highly directional, so mainly pickup in front of them.
eu.audio-technica.com/en/resources/tutorials/Polar%20Patterns.pdf.
(shotgun is the last polar pattern in the pdf)
en.wikipedia.org/wiki/Microphone
Ducktape1, sorry, but here is a quote from the link you gave at wikipedia....""Shotgun" microphones are the most highly directional. They have small lobes of sensitivity to the left, right, and rear but are significantly less sensitive to the side and rear than other directional microphones are."
This link also has a good explanation as well as show the "polar pattern/ recording field" examples for the three most popular types http://lafcpug.org/reviews/review_shotgun_mic.html.
One example, I discovered is when I mic/record acoustic drums. I used to use 2 condenser mics, like the AKC C1000s ( http://pro-audio.musiciansfriend.com/product/AKG-C-1000-S-Condenser-Microphone?sku=271131 ) "boom mounted" about 3-5 feet above the drum kit to pick up primarily the cymbals (other parts of the kit where close mic-ed). Problem was both cardioid and hypercardioid patterns were not narrow enough and I was picking up too much of the rest of the drum kit. As a test I borrowed 2 Rode NTG1 shotgun mics from one of my video friends and tested them. With a bit of tweaking to account for the new mics I found I was picking up MUCH LESS of the drum kit and MUCH MORE of the specific cymbals I wanted (Left only or right only)
One note I have tried virtually every "cheap trick" (musical pun intended) to (1) get by with cheaper mics and/or (2) "force" mics to record (or ignore) more/less than they we designed to do....with a few successes but mostly failures (re: yeah I may have recorded but the quality suffered more than I liked). I even built a "Pringles can attenuator/shock mount" for one of my C1000s...the shoke mount was great...but the sound quality sucked and even had to fight feedback even more so. Thus trying to "force" a "regular mic" to be a shotgun mic might work....but may create more issues.
One final note....I really do like like this instructable as a very good idea for a DIY wind screen....GOOD JOB.
an omni sounds best because no sound can reach the diafragm from behind causi'n fase problems that sound unnatural.
1st Problem: tape leaves residue on mic=not good for mic.
2nd Problem: Spl, aka, the diaphragm will be DESTROYED. if not straight away, it will over a short period of time. A better option if placing a mic on the bell would be the AKG C430, designed for drums AND relatively inexpensive. (no need for tape either) see : http://www.akg.com/site/products/powerslave,id,278,pid,278,nodeid,2,_language,EN.html
love the instructable, maybe work out a way to fit a wired mic. (shouldn't be too hard, and cheaper on mics/batteries over time too)
Bottom line find the best mic designed for whatever you are trying to do with the best mix of quality and price. I have tried virtually every trick in the book with most types of mics and why I have well over $15,000 in just mics...every experiment seemed like a good idea until I heard the recordings and most were not a good idea....but this is still a great instructable!!!!
2.use a -20dB pad.
3.read up on the basics maybe then you'll understand why and how this works and why (if you do this right) it will sound more natural.
4.we where talking about about a recording-session so what is this about feedback???
(if you don't understand techy lingo, which I'm guessing you don't due to your blatant lack of knowledge, cans are headphones used to monitor the recording/let the technician talk to you)
2nd = Blatant lack of knowledge. i.e. microphones have a certain point they get to before they rip apart from the inside, also known as the Max Sound Pressure Level (Max SPL) which is measured in db's (decibels). basically this means that if you have a mic with an 80db spl max, it can only stand up to 80db of audio at the diaphragm. the spl produced by a standard set of cymbals is well above the max spl of the C1000. your diaphragm is screwed, I feel sorry for ALL of your equipment.
http://www.soundprofessionals.com/cgi-bin/gold/item/ATR55
good instructable, i faved it _
