3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Microphone Blimp
Step 3Mount the grip handle
1. Use a hacksaw to cut the roller from the paint roller handle. Ensure that the cut leaves a small amount of tip above the bend, so that this tip can be inserted into the grill for support purposes.
2. Bend the handle away from 90 degree, if desired. In other words, check the angle of the handle in the completed project. I didn't want mine straight up and down when I pointed it at my sound source.
3. Insert the tip that was left after cutting the roller off into the tube grillwork.
4. I used thin brass wire to attach the grip handle and then followed that with epoxy. Your ingenuity is probably better - U-shaped bolts or whatever.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:gezortenplotz
