3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Microreader Kit and Beyond
This kit is essentially a small microreader with an IC attached to it, which gives it data to read. The microreader displays text one letter at a time in a loop. Whenever you restart it, it picks a new phrase from its software at random.
The Microreader kit comes with pretty good, colorful instructions. For the sake of this instructable, an IC socket will be used to promote easy removal of the chip for programming. An IC socket is a bed the integrated circuit (IC) can sit in. This way you can take it out and program it or pet it if you want. You can get it from the Makezine Store.
You can use the MiniPOV as a programmer. No it's not a cheap trick to get more people buying them -- using the MiniPOV to program the Microreader is actually cheaper than buying a standard IC programmer. Alternatively, you can make your own programmer using this instructable.
Using an IC in this project makes it more difficult (annoying) to put together. I bought a cheap 20 pin IC from Radioshack, which I've heard isn't very good. It works fine for this project though. Also, you may consider an IC because this eliminates the possibly of accidentally destroying your IC.
This kit is great for soldering beginners. To learn the basics of soldering check out this great guide by noahw. Also, here's a good video tutorial from the MAKE blog.
Idealy, you can put this little reader on all sorts of stuff. Eventually this guide will illustrate how to temporarily attach this to a piece of clothing.
Step 1What you get and what you need.
This kit is pretty simple.
What you get:
Microreader
Battery Holder (with screw)
IC
What you need:
Soldering iron with a fine tip
solder
2 AA batteries
wire cutter
and if you want to program it using a programmer get a 20-pin IC socket.
The pictured holder isn't 100% necessary but it may help. I found it easier to just do this on a tabletop.
11 comments
Jul 6, 2009. 3:11 PMfkuk says:
how do you program it i get you write the program on the computer then how do you get that on to the chip
Oct 20, 2009. 1:35 PMRadobot says:
Nov 21, 2007. 5:24 PMchrisrock410 says:
how much would this cost?
Jun 12, 2007. 12:34 AMfrank26080115 says:
Using a coin cell would look a lot better
Jun 17, 2007. 5:37 PMMyself says:
The first step could do a much better job of explaining what a Microreader is (it's apparently not the text editor of the same name) and why I'd want one.
Jun 13, 2007. 3:03 PMdeflater says:
Where can you buy these displays? Digikey has some alphanumeric displays but the digits look a lot smaller.
Jun 12, 2007. 1:21 PMjosh92176 says:
If that IC is an attiny 2313 then instead of buying a miniPOV one could make this.
Jun 11, 2007. 9:28 PMongissim says:
So what you did was put an IC socket in place of the IC, just so you can take the IC out to find the message in the source code?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:MAKEkits
