Microsoft Lumia 535 With Broken Touch Screen
4,868
16
9
Posted
Introduction: Microsoft Lumia 535 With Broken Touch Screen
Lumia 535 RM-1090 / RM-1091/ RM-1089 / RM-1092
How to full disassemble the phone and change /replace broken touch glass, LCD screen, loudspeaker / buzzer, earpiece, etc.
Step 1:
- Turn off the phone and remove the battery and any SIM and memory cards.
- Use screwdriver Torx T4 and remove the 9x black screws.
- Use a plastic pick or other plastic tool to separate the rear bezel.
Step 2:
- Disconnect:
  1. Touch screen flex cable
  2. LCD Display flex cable
  3. Charging Dock board flex cable
  4. Coaxial antena cable
- Remove the 2x Torx T4 screws.
Step 3:
Lift the board from the LCD flex connector side and remove it.
Step 4:
- Remove the LCD flex rubber.
- Put scotch tape on the glass to prevent it from shattering.
- With a hair dryer or heat gun and warm the glass to soften the adhesive.
Step 5:
- Use a cutter or other tool with a sharp edge and start the separating from the bottom side. When you make enough room, continue the operation with a plastic tool.
- Work slowly and do not force the frame with the display too much.
- If necessary, warm again the glass with a hairdryer.
Step 6:
- Put adhesive tape 2mm on the digitizer glass.
- If you can, order the digitizer glass together with an adhesive tape. The replacement is easier.
- Install the touch screen and start with the reassembling.
!!! There are different versions touch screens. The version is printed on the flex cable !!!
CT2S1973FPC-A1-E, CT2C1607FPC-A1-E
Step 7:
That's all.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
9 Comments
How do I know what screen to use?
do you have any instructables for Lumia 1520
Awesome repair job. Much cheaper than taking a phone to a repair shop.
yeah it does I fix them for people. but I charge a hole lot less nether the less it's. very helpful and fun☺
(ツ)
Hi, idid exactly the same as in the video, but the screeb doesnt respons to it, i have both touch screens, both of them do not respons, can you help me with that plz.
it's the way u pluged it in before I would no I fix them for a living☺
There are different versions touch screens:
CT2S1973FPC-A1-E
CT2C1607FPC-A1-E
The version is printed on the flex cable.
Wish I had read your Instructable before buying the screen and attempting the transplant. the model numbers do seem to make a difference in the operation. I have to go look for the correct version.
Thanks for the extra information. Cheers
