This is my first Instructable, And still a work in progress. The steps to preparing and putting glass canning jars with metal lids in the Microwave oven and create enough heat to sterilize and vacuum seal the jars.
All Steps Viewing
I canned jars of numerous foodstuffs to test. Food is edible and seems to be sterile.I don't trust beef or pork.Salmon worked well.Chicken seems to work OK too..all vegetables worked good..fruits the same..Here are the concerns I am wrestling with.1. Even though it is vacummed sealed I don't know with absolute certainty that the product is FREE of latent microorganisms that could culturize over time,say three months. I left my test samples for seven days without refrigeration. 2. my next concern is that the pressure that builds from processing in the microwave bleeds out during the sterilazing process and carries minute particles out across the seal surface.even though it effectively seals I am not sure that a culture would not build under the seal over time from the contamination during the original processing..food needs to be tested for longer then the one week that I allowed for this test to see what happens.
With the pressure canning method there is pressure on the outside and eventually on the inside of the canning jar..the pressures balance each other and therefore NO residual contaminant is carried across the sealing surface..A great big difference the way I see it...My conclusion SO FAR:...the micro method can be used safely on a short term basis..prepare the food for the upcoming week and CAN it to save time later in the week..for serious long term use it is best to use a pressure cooker ..I have a digital one with timers and auto shut off functions that make canning easy...If I find out anything else I will post it here...jeffmika@gmail.com
If you want to test the metal issue, just leave a teaspoon in a coffee cup when reheating your coffee or heating water.. There is no ill effect. But don't let any metal touch any of the sides!
I would only do this if I was planning on throwing out the microwave.. any metal in the microwave can cause damage
http://answers.yahoo.com/question/index?qid=20090705052859AAftUAB
Crazy I tell ya!
This method has been done in Australia - SUCCESSFULLY since the microwave oven was invented.
