Microwave Corn
Microwave Corn
There's no shorter path between you and delicious, piping hot corn on the cob, than via the microwave! This microwave corn on the cob recipe will show you the tips and tricks you need for perfect corn every time.  Once you try it, you'll never go back to boiling again!
Step 1Materials
Materials
Corn on the cob - unshucked
Towel
Paper towel or plate
Microwave
53 comments
1-40 of 53next »
Aug 13, 2011. 12:45 PMcHOCO-pOCKEY, says:
You could also wrap it in seran-wrap -- it's what I do, and it works marvelously.
Aug 11, 2011. 4:14 AMcinstallers says:
Ive just tried this at home and it worked great. Thanks.
Aug 7, 2011. 9:42 AMAnna Boone says:
I always just pull the shucks back, whack'em off part way and use as a handy handle. The corn is good Mexican style with mayo. and sprinkle of Parm cheese.
Jul 25, 2011. 7:33 AMfletchprint says:
I usually infuse a little water in the husk to help it steam. Its a necessity for grilling in the husk. Open the end a little, hook to a faucet or hose turn on....done.
Jun 19, 2011. 4:15 PMbajablue says:
I'm a shuck, wrap and nuke Gal... but I'm going to try it your way tonight, Scooch.
Jun 24, 2011. 8:32 PMbajablue says:
oh... my... GOSH! This was the BEST corn on the cob I've ever tasted in my whole entire LIFE!
No more saran wrap for me, ever again!!!
Jan 20, 2011. 3:30 PMsoapbox derby car says:
I love how simple this is, but I never would have thought of this myself! thanks!
Nov 25, 2010. 8:54 AMycnax says:
Microwaving corn in its husk makes the most delicious ear.
Nov 23, 2010. 2:27 AMpaqrat says:
Being an ignorant bachelor what would you reccomend for cleaning the corn before nuking? Is rinsing enough?
Mar 26, 2009. 3:45 PMLemonLily says:
Butter your corn if you'd like!
Jul 24, 2009. 9:13 AMthepelton says:
I like it buttered, beleive me, but I was told my bad cholesterol was too high, so I almost gave butter up.
Nov 23, 2010. 2:21 AMpaqrat says:
I needed to cut back on some of the high cholesterol foods I was eating. I discovered Parkay Spray. 0 fat, 0 transfat, and 0 cholesterol. It tastes to me as good as the margerine I had been using. Being a spray it works best on things like baked potatoes and corn on the cob but I have used it on hot breads. I know Wal-Mart carries it in the same area as the margerines.
Jul 24, 2009. 4:39 PMGoodhart says:
just stay away from those trans-fats in some of the margarines !
Nov 21, 2010. 3:41 PMmattgallion says:
microwave it wrapped in Saran wrap. no lie, it works.
Nov 21, 2010. 3:38 PMmsean says:
I like to just peel back the husk and use it for a handle.
Nov 21, 2010. 1:20 PMRex_C says:
When I was a kid in WV, low those many years ago, we seasoned hot bacon grease with salt and pepper and rolled our boiled corn in it!! Yum-Yum
Of course we didn't know what cholesterol, good or bad, was and never heard of trans-fats. Micro-wave, just a little ripple in the crick.
Love it anyway I can get it now. Sometime, if the corn is already shucked, try wrapping in a wet paper towel and micro-waving.
Nov 21, 2010. 10:56 AMjtharkness says:
I have nuked corn with great results though never wrapped it with a towel before. I will try this asap though Nov in PA is long past corn season. And I certainly agree that ripe corn on the cob is divine. Someone mentioned grilled corn but shucked first. I highly recommend grilling COTC using the same principle as microwaving - unshucked. You also don't need the towel when grilling. While you are grilling your main dish, place the unshucked corn on the upper shelf of the grill or on the sides, away from direct heat or flame, and turn it 5-10 minutes later. I usually just turn it when I turn the meat. 5-10 minutes after turning it just remove it from the grill and within seconds the corn is cool to the touch and ready to be shucked, and, of course, delicious. I always marvel at how quickly the COTC cools down - the silk and leaves must be natures most perfect heat dissipater.
Nov 21, 2010. 7:37 AMMark Rehorst says:
Great 'ible, but I beg to differ on one point. If you're firing up the grill for a BBQ the best way to prepare COTC is to grill it Japanese-style. Put shucked corn on the grill, rotate frequently, and brush with soy sauce just before removing from the grill.
Feb 4, 2010. 3:34 PMboogiemanspud says:
 This is how we cook corn, but haven't used the towel.  One hint that I have found, don't try to shuck the corn.  Instead, go in about 1/2" from where the stem is and just cut the end off.  If you do it right it wont hurt the final row of corn.  Then, grab the corn by the hairy end and shake it really hard, the corn will fall right out with no hair/silk left on the corn.
Nov 15, 2009. 8:54 AMred-king says:
 barbecued corn is good too...
Aug 4, 2009. 4:34 PMRe-design says:
I tried this tonight. I couldn't believe it was gonna be as good as my usual method. But I was wrong. This way of cooking is way better. I'll never boil corn again. I like mine with salt and "I can't believe it's not butter". I can use all I want and there ain't no extra calories. ( I don't care what it's made of).
Jul 26, 2009. 9:59 PMpiperjon says:
You're my HERO! Swooon! I loooove corn on the cob, so now I have a means by which to prepare it. Thank you! - Pj
Jul 26, 2009. 8:12 AMsarahsmom says:
glad you haven't forgotten where your roots are!
Jul 25, 2009. 5:52 PMunphazed says:
I usually just shuck the corn, then place into a small sandwich bag with butter and water. Microwave in 1 minute increments, tossing the corn in the bag each time. 3 minutes later, poof, done and done.
I am unable to eat it off the cob anymore :.-..(
Jul 23, 2009. 7:37 PMjessyratfink says:
I haven't tried it this way. I've been doing them in the oven in foil and they turn out pretty well! But this will definitely keep my tiny kitchen cooler!
Nov 6, 2008. 1:31 PMmg0930mg says:
Cool, when I get corn on the cob, I'll do this, how good is it? Does it taste just like boiled?
Feb 15, 2009. 8:19 PMthepelton says:
I have nuked corn on the cob before, and I like it. It seems to cook fine, and doesn't taste any different to me.
Feb 15, 2009. 8:23 PMmg0930mg says:
We haven't got corn on the cob in a while.... I'll have to get some soon.
Feb 15, 2009. 10:40 PMthepelton says:
The fresh stuff is out of season here in Colorado.
Feb 16, 2009. 9:44 AMmg0930mg says:
I don't know when it's in season, I know it's not peach season, though. I love peaches.
Feb 17, 2009. 9:59 AMthepelton says:
The season, at least in Colorado, is late spring to early fall. May to September, and that may be pushing it a bit.
Feb 17, 2009. 12:02 PMmg0930mg says:
I think that's what it is here,too...
Jun 17, 2009. 9:31 AMthepelton says:
The Corn on the Cob season has begun here in Colorado, and I have been getting some at the nearby Farmer's Market. Lovely!
Jun 21, 2009. 4:07 AMmg0930mg says:
Good, I'll ask my dad to go to the farmer's market, to pick up some corn. :)
Jul 23, 2009. 2:16 PMthepelton says:
I have gotten used to eating it without salt or butter, and it's probably more healthy for me that way.
Jul 23, 2009. 8:11 PMmg0930mg says:
Yeah, I still like it with butter, but will substitute it with margarine!
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
3433
Author:scoochmaroo(My fan page)
Editor of the Food and Living channels.
